<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 157]]></title><description><![CDATA[<h3>VectorStyler beta 157 release notes</h3>
<li>Improved: added OpenType variable font support.</li>
<li>Improved: color and variable fonts are shown with different icons.</li>
<li>Improved: show number of font family members next to the name.</li>
<li>Improved: added <em>WEBP</em> format for both import and export.</li>
<li>Improved: added the <em>Pixels</em> unit.</li>
<li>Improved: accessibility and <em>Better Touch Tool</em> support.</li>
<li>Improved: 4 Point distortion should keep lines.</li>
<li>Fixed: crash with certain open outline shifting mode.</li>
<li>Fixed: text on path tool should work with local text baseline paths also.</li>
<li>Fixed: touching the text baseline with the node tool to create text on path effect.</li>
<li>Fixed: the <em>Go Back</em> button in the isolated editing indicator resulted in broken document state.</li>
<li>Fixed: the name of a closed file may remain visible in the title bar.</li>
<li>Fixed: assigning pattern fill from the fill popup preset list did not udate the object fill.</li>
<li>Fixed: proportional scaling to also work when pressing <em>Shift</em> before the mouse press.</li>
<li>Fixed: duplicating pattern styles did not refresh.</li>
<li>Fixed: better indication of the collision point in the collider tool.</li>
<li>Fixed: automatically group selected objects when activating a distortion effect tool.</li>
<li>Fixed: organize gradient presets into folders.</li>
<li>Fixed: <em>Pen</em> tool was broken when direct preview mode was disabled.</li>
<li>Fixed: hue, color, saturation and intensity blend modes were broken.</li>
<li>Fixed: crash when using blend modes.</li>
<li>Fixed: pattern was not aligned globally when used in transparency.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/104/build-157</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:34 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/104.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Aug 2020 06:22:17 GMT</pubDate><ttl>60</ttl></channel></rss>
