<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 1.1.0 (beta)]]></title><description><![CDATA[<p dir="auto">This build is a beta of version 1.1, and it works as a regular release (no restrictions with license, regular trial mode without license).<br />
The beta only means that the main download and the app store version is not updated yet.</p>
<p dir="auto">How to get the beta:<br />
Manual update: VectorStyler -&gt; Check For Updates (Mac) or Help -&gt; Check For Updates (Windows)<br />
Or, download from the release page: <a href="https://www.vectorstyler.com/releaselog/" rel="nofollow ugc">https://www.vectorstyler.com/releaselog/</a><br />
(that is, does not automatically notify for update).</p>
<p dir="auto">The following fixes and improvements included:</p>
<h4>Improvements</h4>
<li>Formulas in number editors.</li>
<li>Customize path node type indicator shapes.</li>
<li>Hold Option (Alt) to draw shape text of some size.</li>
<li>Incremental saving.</li>
<li>Search field in preferences to find settings by name or tool tip text content.</li>
<li>Symbol stamp tool: place the selected symbol with mouse clicks.</li>
<li>Repeater: create automatic repetitions of multiple objects to fill shapes.</li>
<li>Symbol painter tool: place with symbols while dragging the mouse.</li>
<li>Symbol position, sizing and rotating brushes.</li>
<li>Symbol coloring and opacity brushes.</li>
<li>Quick look plugin for MacOS.</li>
<li>Alignment panel geometric mode to be persistent.</li>
<li>Select page fill when selecting color while the Artboard tool is active.</li>
<li>Path brush mode to change selected objects only.</li>
<li>Option to disable smooth scrolling and zooming modes in Preferences -&gt; Document Editor.</li>
<li>Option to expand stroke when exporting to vector formats.</li>
<li>Persistent default values in Offset Path view.</li>
<li>Immediate search field editing in font drop down.</li>
<li>Hold Control to draw line in path brush, eraser and knife tools.</li>
<li>Modifier key to adjust scroll rounding in number fields.</li>
<li>Increase default precision for numbers exported into text based formats (SVG).</li>
<li>Layers panel option to select object on canvas on Control+Click.</li>
<li>Double click action configuration in Preferences -&gt; Document Editor.</li>
<li>Show alignment options in context panel for single objects also, to align to artboard.</li>
<li>Better default scrolling direction on windows.</li>
<li>Control+Backspace to clear a number or text input field.</li>
<li>Paste attributes from copied objects.</li>
<li>Improved selection of small objects.</li>
<li>Pick colors using a color panel tool.</li>
<li>Convert lines to cubic curves when setting smooth / symmetric corner.</li>
<li>Better color panel layout.</li>
<li>Add shortcut (Control+Shift+K) to find and highlight selected object in the Layers panel.</li>
<li>Options to control the scaling and transformation of image effect parameters.</li>
<li>Option to keep transform tool mode: Preferences -&gt; Document Editor -&gt; Keep Selection Mode.</li>
<li>Better backgrounds and customization for previews in Layers panel.</li>
<li>Compact Layers panel menu by default (option for the larger menu in the panel options).</li>
<li>Set brush size from context panel for shape effect brushes.</li>
<li>Bitmap exporting mode, without dithering.</li>
<li>Persistent tool selections inside groups of the toolbox.</li>
<li>Selecting the panel menu should bring it forward if obscured.</li>
<li>Proportional dragging of smooth nodes (hold Option or Alt).</li>
<li>Import AI data from EPS files (Preferences -&gt; Document Files -&gt; Import AI Data from EPS).</li>
<li>Snap to start / end node when editing nodes.</li>
<li>Update Missing fonts view if fonts are rescanned.</li>
<li>Buttons in Stroke panel to sync cap and arrow styles.</li>
<h4>Fixes</h4>
<li>Guideline direction swapping when pressing Option (Alt) key.</li>
<li>Rename "Locked" to 'Lock Object.</li>
<li>Popover panels to be on top of regular floating panels.</li>
<li>Reset node corner types when a path is imported from AI format.</li>
<li>Layers panel synchronized selection modes.</li>
<li>Improve Ai file format import support.</li>
<li>Ungrouping a layer caused refresh problems.</li>
<li>Scrolling with touchpad on Windows.</li>
<li>Show highlight nodes in path brush and eraser tools.</li>
<li>Transform each to use center correctly.</li>
<li>Correct Undo / Redo name for path brush and erase tools.</li>
<li>Scaling selected nodes should scale handles correctly.</li>
<li>Pasting inside object to consider object transformations.</li>
<li>Draw and drop in Layers panel into an object should adjust positions.</li>
<li>Corner editor on multiple objects with different scaling or transforms.</li>
<li>3 point drawing tools should snap to point even when snapping is disabled.</li>
<li>Noise blur should not depend on zoom.</li>
<li>Right angles in zig zag corner presets.</li>
<li>Scaling objects should also scale the pivot location.</li>
<li>Variable width stroke profile should blend correctly.</li>
<li>Blending smooth nodes should retain smoothness.</li>
<li>Handle empty text lines correctly for the object bounding box.</li>
<li>Possible crash when duplicating objects with styles.</li>
<li>Navigator panel content display on Windows.</li>
<li>Possible crash when updating the History panel.</li>
<li>Crash if using MacOS system color palette when tracing images.</li>
<li>Possible crash when pasting a bitmap from Firefox on Windows.</li>
<li>Do not select object, when clicked inside small negative spaces.</li>
<li>Do not show nodes of locked objects, when selected.</li>
<li>Placing blend objects inside another object should refresh correctly.</li>
<li>Undo and Redo to work correctly for blend object changes.</li>
<li>Keep stroke width profile when changing between a brush and stroke.</li>
<li>Better mouse wheel scrolling in number fields.</li>
<li>Layout of shape panel popover is broken when opened from the context panel.</li>
<li>Rendering the arrow on stroke should composite with the stroke correctly when opacity or blend mode is used.</li>
<li>Exporting transparency masks to PDF.</li>
<li>Transform object pivot point correctly, when inside transformed layers.</li>
<li>Undo / Redo of some object placement action may remove the object.</li>
<li>Undo should remove empty group content.</li>
<li>Font preview position in font list.</li>
<li>Show Custom artboard format if width or height is edited.</li>
<li>Undoing certain ungroup actions.</li>
<li>Moving cursor to the last position of an edited text.</li>
<li>Enable standard ligatures by default.</li>
<li>Rasterizing objects in CMYK documents.</li>
<li>Do not open corner modal view when double clicking in corner editor.</li>
<li>Hiding an object shows the wrong frame inside transformed layers.</li>
<li>Deleting linked images from the document.</li>
<li>Stroke width discontinuity at the starting node, caused by the width tool.</li>
<li>Allow shortcuts when keys are pressed while a panel is focused.</li>
<li>Detach style references before deleting the style.</li>
<li>Better precision when exporting expanded stroke to SVG.</li>
<li>No need refresh layers panel previews at any change.</li>
<li>Moving minified panels at the top edge of the screen.</li>
<li>EMF exporting issues.</li>
<li>Better favorite icon for fonts.</li>
<li>Better refreshing certain halftone effect changes.</li>
<li>Set correct version number when exporting EPS files.</li>
<li>Transparency mask editing in isolated mode.</li>
<li>Font group name change is not registered in the font manager.</li>
<li>Save warning dialog box when original save location unavailable.</li>
<li>Template file name selection in preferences.</li>
<li>Crash on MacOS M1 when opening files with hyphenation enabled text.</li>
<li>Inside Last action should identify target object correctly.</li>
<li>Direction of indicators in gear shape editing.</li>
<li>Importing vertical text from AI file format.</li>
<li>Exporting to SVG to handle qualified names correctly.</li>
<li>Default Layers panel width on Windows is wrong.</li>
<li>Improve JPEG file importing.</li>
<li>Convert text on path to curves: should keep positions correctly.</li>
<li>Aligning nodes vertically.</li>
<li>Allow the selection of locked objects with selection similar and select by attribute.</li>
<li>Refreshing issues when objects are pasted from AI to VS.</li>
<li>Floating toolbox is positioned at the bottom after restart.</li>
<li>Option to block context panel undocking.</li>
<li>Magic wand to use selection by attribute on the current canvas only.</li>
<li>Refresh issues after certain duplicate actions.</li>
<p dir="auto">Many of the recent bug reports are not yet addressed due to insufficient time, but will be in upcoming builds.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/1208/build-1-1-0-beta</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1208.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Dec 2021 13:34:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 1.1.0 (beta) on Thu, 16 Dec 2021 10:49:20 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Thanks, it would be so great <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /> I'm looking forward to seeing this development too <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/6233</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6233</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Thu, 16 Dec 2021 10:49:20 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Thu, 16 Dec 2021 10:14:58 GMT]]></title><description><![CDATA[<p dir="auto">@PatrickM said in <a href="/forum/post/6222">build 1.1.0 (beta)</a>:</p>
<blockquote>
<p dir="auto">VS already allows precise layout of text and graphics and I am wondering if later on, it could be considered to be developed to allow desktop publishing (like InDesign).</p>
</blockquote>
<p dir="auto">Maybe further down the road <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/6226</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6226</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 16 Dec 2021 10:14:58 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Thu, 16 Dec 2021 09:43:48 GMT]]></title><description><![CDATA[<p dir="auto">VS is really rich in features and may become the replacement of other vector apps (&amp; third party plugins).<br />
VS already allows precise layout of text and graphics and I am wondering if later on, it could be considered to be developed to allow desktop publishing (like InDesign).<br />
Just a question...</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6222</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6222</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Thu, 16 Dec 2021 09:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Tue, 14 Dec 2021 14:39:22 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it's an impressive list.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6162</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6162</guid><dc:creator><![CDATA[fde101]]></dc:creator><pubDate>Tue, 14 Dec 2021 14:39:22 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Tue, 14 Dec 2021 10:37:39 GMT]]></title><description><![CDATA[<p dir="auto">Really Great ! Thank you <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" />  I was waiting for this version and some fixes to continue learning VS (I am only at the ten thousandth of the possibilities of VS... well maybe even less <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /> ).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6138</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6138</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Tue, 14 Dec 2021 10:37:39 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Tue, 14 Dec 2021 09:54:27 GMT]]></title><description><![CDATA[<p dir="auto">Can only agree with all other comments,  i am also impressed.<br />
Well done, as always <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/6136</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6136</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 14 Dec 2021 09:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Tue, 14 Dec 2021 00:57:03 GMT]]></title><description><![CDATA[<p dir="auto">This is indeed a great new version - many improvements, many obstacles removed... and the software shines!</p>
<p dir="auto">It feels like I got a brand new and much better program!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6102</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6102</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 14 Dec 2021 00:57:03 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Tue, 14 Dec 2021 00:50:31 GMT]]></title><description><![CDATA[<p dir="auto">This is a really impressive build! I've barely scratched the surface going through everything and I'm already blown away! VS gets better all the time!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6100</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6100</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 14 Dec 2021 00:50:31 GMT</pubDate></item><item><title><![CDATA[Reply to build 1.1.0 (beta) on Mon, 13 Dec 2021 18:24:02 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Looks like the "Formulas in number editors" got disabled in the final build.<br />
I will upload a fix ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6056</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6056</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 13 Dec 2021 18:24:02 GMT</pubDate></item></channel></rss>
