<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 165]]></title><description><![CDATA[<h3>VectorStyler beta 165 release notes</h3>
<li>Improved: both dark and light UI themes are redesigned.</li>
<li>Improved: panel design.</li>
<li>Improved: unified slider styles in all panels and views.</li>
<li>Improved: handling undocked toolbox menus.</li>
<li>Improved: reorganized complex modal views.</li>
<li>Improved: horizontal panel docking for suitable panels (not containing lists).</li>
<li>Improved: expand stroke precision is adjusted by zoom level.</li>
<li>Changed: do not keep transforms when converting an object to curves (will clear image transforms).</li>
<li>Fixed: possible crash when rendering complex drawings containing transparency masks.</li>
<li>Fixed: simplify path to take into account cusp corners.</li>
<li>Fixed: drag content from <em>Content Links</em> panel directly on the canvas (without a shape).</li>
<li>Fixed: activating tools while the collider tool will not deactivate the collider tool.</li>
<li>Fixed: added <em>Expand Content</em> to the image trace panel menu.</li>
<li>Fixed: share <em>Preview</em> checkbox state between views of the same domain.</li>
<li>Fixed: crash when scrolling on font sizes with a newly created text frame selection.</li>
<li>Fixed: enforce winding mode when converting shape text to curves.</li>
<li>Fixed: text underline to use default and local text styling.</li>
<li>Fixed: scrolling with mouse while editing may break the editor.</li>
<li>Fixed: editing concentric ellipse positions.</li>
<li>Fixed: move views only from title.</li>
<li>Fixed: toolbox button tool tips to include short tool name first.</li>
<li>Fixed: editing breaks when mouse dragged outside of editor area (or over a panel).</li>
<li>Fixed: possible crash in pixelate and pointilize image filters.</li>
<li>Fixed: point and shape snapping modes was very slow for complex shapes.</li>
<li>Fixed: possible crash in metal display on Sierra.</li>
<li>Fixed: possible crash when rendering adjustment effects with CMYK display mode.</li>
<li>Fixed: snapping to points works for all intersections.</li>
<li>Fixed: disabled Metal support for Intel HD 4000 (compute is not supported well by metal driver).</li>
<li>Fixed: some partially visible text may not show.</li>
<li>Fixed: improve preset panel performance.</li>
<li>Fixed: center or right aligned text initial baseline path was wrong.</li>
<li>Fixed: convert linked text on path to curves.</li>
<li>Fixed: ungrouping imported SVG shapes could move the group.</li>
<li>Fixed: positioning imported files into the artboard.</li>
<li>Fixed: when a file is dropped inside the document, it should always import.</li>
<li>Fixed: paste object from clipboard to the view center when original position was outside of the visible area.</li>
<li>Fixed: enable shift+click to deselect objects.</li>
<li>Fixed: select and change two or more rounded corners.</li>
<li>Fixed: reverted document should not be indicated as modified.</li>
<li>Fixed: ungrouping an object with opacity will distribute the opacity among the member objects.</li>
<li>Fixed: changing parameters of grouped shape should change the shape (and not apply a clipping shape on the group).</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/127/build-165</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:49 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/127.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Sep 2020 21:42:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 165 on Mon, 21 Sep 2020 07:24:56 GMT]]></title><description><![CDATA[<p dir="auto">Happy to help <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/382</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/382</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Sep 2020 07:24:56 GMT</pubDate></item><item><title><![CDATA[Reply to build 165 on Mon, 21 Sep 2020 05:41:06 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/380">build 165</a>:</p>
<blockquote>
<p dir="auto">Also: when using Image Effects the shapes are rasterized, but otherwise no rasterization occurs.<br />
The distortion effects are available as both Image Effects and Shape Effects. You want to use Shape Effects to distort and keep shapes.</p>
</blockquote>
<p dir="auto">That is exactly what it was. I mistaking Image effects and Shape effects! It even tells the apparent difference on the official tutorial page when actively read.</p>
<p dir="auto">I guess I got a little too spoiled with vectors that I forget people need to work with rasters too. I know I do on my phone when I am often out and about in the car all day with my family and can't access my mac.</p>
<p dir="auto">I forgive myself as other people who might make the same mistake will probably run into this thread and also be like "Oh... silly me!".</p>
<p dir="auto">Thank you for being flexible by the way. It is a quality that will Make Vector styler a success!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/381</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/381</guid><dc:creator><![CDATA[Joyco]]></dc:creator><pubDate>Mon, 21 Sep 2020 05:41:06 GMT</pubDate></item><item><title><![CDATA[Reply to build 165 on Mon, 21 Sep 2020 05:23:23 GMT]]></title><description><![CDATA[<p dir="auto">This might be caused by a settings reset (required for this new install).<br />
Go to Preferences -&gt; Performance section and see if <em>Copy as PDF</em> or <em>Copy as SVG</em> are checked.<br />
Depending on the other app (to paste to), you may want to enable both (small performance hit when copying to clipboard). You could also disable <em>Copy as PNG</em> and <em>Copy as TIFF</em> to avoid placing images onto the clipboard.</p>
<p dir="auto">Also: when using <em>Image Effects</em> the shapes are rasterized, but otherwise no rasterization occurs.<br />
<p dir="auto">Let me know if this works for you.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/380</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/380</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Sep 2020 05:23:23 GMT</pubDate></item><item><title><![CDATA[Reply to build 165 on Mon, 21 Sep 2020 05:05:24 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/369">build 165</a>:</p>
<blockquote>
<p dir="auto">Changed: do not keep transforms when converting an object to curves (will clear image transforms).</p>
</blockquote>
<p dir="auto">So does this the reason I can no longer seem to copy and paste my desired distorted vector shapes and paste them anywhere on any vector app. That is, I used to be able to do that and the nodes would automatically convert to sharps nodes but maintain the smooth shape with the handlers.</p>
<p dir="auto">Any way around this to keep the vectors true to the desired shape? or is it straight to the bitmap trace they go?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/379</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/379</guid><dc:creator><![CDATA[Joyco]]></dc:creator><pubDate>Mon, 21 Sep 2020 05:05:24 GMT</pubDate></item></channel></rss>
