<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 1.1.002 (beta)]]></title><description><![CDATA[<h3>VectorStyler 1.1.002 Beta release notes</h3>
<p dir="auto">EDIT: as before, a manual "Check for Updates" is required for this build (while in beta)</p>
<h4>Improvements</h4>
<li>Select locked layers also, when selecting with <em>Locked Objects</em>.</li>
<li>Selection mode to select empty layers.</li>
<li>Option to transform layer members, when a layer is selected (Allow Layer Transformations).</li>
<li>Hold Option (Alt) when confirming scale or size values in the Transform panel, for proportional scaling.</li>
<li>Add Reset button to transform panel.</li>
<li>Pasting should center at visible area after panned or zoomed.</li>
<li>Draw inside mode, and access from context panel.</li>
<li>Drag&amp;drop a VS preset file on the app window to open the preset panel.</li>
<li>Shortcuts for transform modes (N for pointer, D for deep).</li>
<li>Save As panel to open at the folder of the file.</li>
<li>Show in Finder button in Document Info panel.</li>
<li>Show the file location in Finder when Option+clicking the document title leaf.</li>
<li>Option to position repeating objects separately on multiple glyph shapes.</li>
<li>Add shortcuts to adjust word spacing (Control+Option+Left/Right on Mac).</li>
<li>Option to disable or change initial filler text (Preferences -&gt; Document Files).</li>
<li>Option to add user folders for hyphenation dictionary files.</li>
<li>Control+B to paste below all objects if none are selected.</li>
<li>Shortcut L to be assigned to the Path Sketch tool.</li>
<li>Context panel to show top or active stroke options.</li>
<li>Close path when moving an ending node over the other and holding Option (Alt).</li>
<li>Option(Alt)+Delete in Node editor to remove segments and disconnect path.</li>
<li>Better font list layout.</li>
<li>Better Stroke panel layout (both vertical and horizontal mode).</li>
<li>Use selected objects in Object Sprayer tools.</li>
<li>Show nodes in text shapes also when hovering.</li>
<li>Copy and paste text on path should copy the linked shape also.</li>
<li>Keep group hierarchy and names when exporting to SVG.</li>
<li>Layer renaming in the Layers panel.</li>
<li>Add foreign file formats to Open Recent list.</li>
<li>Shift+E shortcut to be used for the Eraser tool.</li>
<li>Shift+B shortcut to be used for the Path Brush tool.</li>
<li>Load editable AI data from PDF files if available.</li>
<li>Keep angle of control point when holding Shift in Node editor.</li>
<li>Allow randomization when Transform Each is enabled.</li>
<h4>Fixes</h4>
<li>Undoing the removal of an object linked to the text on path.</li>
<li>Repeating duplicate with scale should adjust scaling pivot correctly.</li>
<li>Hue sliders showed wrong hue positions.</li>
<li>External display issues on Windows.</li>
<li>Language menu in Characters panel is too large.</li>
<li>Image effect mask for White Noise image effect.</li>
<li>Move window canceling when opened with Enter.</li>
<li>Change visibility mode of multiple highlighted items in the Layers panel.</li>
<li>Moving, scaling and rotating inside transformed layers.</li>
<li>Delete Empty layers from Layers panel menu.</li>
<li>Setting corner radius from the context panel.</li>
<li>Overlapping shape exclude.</li>
<li>Pressing space for panning breaks node and transform editors.</li>
<li>Selecting symbol sets with marque.</li>
<li>SVG importing problems.</li>
<li>Do not create objects when the active layer is locked.</li>
<li>Possible crash when detaching clone objects.</li>
<li>Hovering over active (blue) buttons should indicate with color.</li>
<li>Import files centered to visible view region.</li>
<li>Double click action in shape editor.</li>
<li>Did not always select all value in number fields when gaining focus.</li>
<li>Larger number fields in Add Noise image filter options view.</li>
<li>Cannot undo after creating plain repeaters.</li>
<li>Better repeater performance with complex shapes.</li>
<li>Paste image from Safari.</li>
<li>Importing SVG markers.</li>
<li>Transform handle sensitivity.</li>
<li>Configurable eraser tool paint area.</li>
<li>Some action names were wrong in the shortcut editor.</li>
<li>Clicking on an icon in the Layers panel should not deselect.</li>
<li>Copy and paste blend objects should not rename it.</li>
<li>Changing current value with expressions, in number fields.</li>
<li>Panning cursor to have a contour.</li>
<li>Crash when using tiling patterns as masks in SVG displacement filters.</li>
<li>Show correct artboard format in context panel.</li>
<li>Moving the rotation pivot of a straight line.</li>
<li>Create correct text shapes when using missing glyphs.</li>
<li>Angle constrain handling in Node editor.</li>
<li>Anchor tool issues when shape has rounded corners.</li>
<li>Import SVG files at correct size.</li>
<li>Remove the "X" shortcut from the Node editor, to allow color mode swapping.</li>
<li>Add scaling to object when transforming objects with transparency masks.</li>
<li>Problems with shortcuts on Windows.</li>
<li>Adding single letter shortcuts on Windows.</li>
<li>Dual screen issues on Windows.</li>
<li>Tooltip did not always display on Windows.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1282/build-1-1-002-beta</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:20 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1282.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Dec 2021 16:26:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 1.1.002 (beta) on Wed, 29 Dec 2021 12:35:29 GMT]]></title><description><![CDATA[<p dir="auto">I found a few bugs / regressions (expected in a beta) but again a <em>very</em> nice update of VS. Appreciated!</p>
<p dir="auto">Also illustrates the hard work that lies in between coding main features - optimizing, stepping back, fixing bugs and preparing for the future (architechture).</p>
<p dir="auto">It is great to see how much work customers also put into the product by providing feedback. A path is formed by laying one stone at a time.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6669</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6669</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Wed, 29 Dec 2021 12:35:29 GMT</pubDate></item></channel></rss>
