<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quicker Access to Toggling Node Removal Curvature?]]></title><description><![CDATA[<p dir="auto">At first, I was not interested in using the "Node Removal Curvature" in my work. Usually I wanted nodes deleted and did not like that it did not give me crisp results. Later I realized there was a great value in being able to use it to make quick edits to curved paths in particular. I still find myself needing to switch back and forth between having this feature on and off based on what I am editing. If I am deleting nodes from a straight path, I like to have the setting off so it does not make the line wonky. When I am editing curved segments, I like to leave it on... I switch often enough that I wish the toggle was not buried in the preferences. I also do not want to clog up the space in VS UI. <img src="/forum/assets/uploads/files/1640733114352-49f73ac9-95c2-4608-b400-01a4da347134-image-resized.png" alt="0_1640733113571_49f73ac9-95c2-4608-b400-01a4da347134-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/1293/quicker-access-to-toggling-node-removal-curvature</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 16:54:59 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1293.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Dec 2021 23:12:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quicker Access to Toggling Node Removal Curvature? on Wed, 29 Dec 2021 05:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I think the best way is to have some Modifier+Delete assigned as a separate action for this.<br />
But then it will be separate from the regular delete action (if the shortcut is customized, these must be assigned separately).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6653</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6653</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 29 Dec 2021 05:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to Quicker Access to Toggling Node Removal Curvature? on Wed, 29 Dec 2021 00:25:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I'm in no way suggesting that Option-Delete is a workaround for what you ask — I just mentioned what Option-Delete does so you know that the Option key is used already, and also because it's newly implemented in the latest beta (thanks, @vectoradmin!).</p>
<p dir="auto">Anyway, a keyboard modifier would be the best in my opinion — Shift + Delete probably.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6639</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6639</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Wed, 29 Dec 2021 00:25:07 GMT</pubDate></item><item><title><![CDATA[Reply to Quicker Access to Toggling Node Removal Curvature? on Wed, 29 Dec 2021 00:03:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> I think it's the opposite way from what you said - if I enable that setting in preferences, then each time I go delete nodes, the remaining path and nodes adjust. This is great for curved paths in particular.... but when I want to do no-nonsense just delete nodes and make the path that remains straight, I turn it off.</p>
<p dir="auto">I just tested the Option/Alt + Delete option you suggested but that is overkill and as you mentioned, it also disconnects the path.</p>
<p dir="auto">i think what I'm wanting is a way to quickly toggle between the node removal curvature and standard deleting of nodes while maintaining the integrity of the path if that makes sense.<br />
I will do a video and share what I mean.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6637</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6637</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 29 Dec 2021 00:03:41 GMT</pubDate></item><item><title><![CDATA[Reply to Quicker Access to Toggling Node Removal Curvature? on Tue, 28 Dec 2021 23:27:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> Should Shift-Delete be used for this — if 'Adjust Node Removal Curvature' is enabled you would get a straight path, and vice versa (a curvature) if the option is disabled?</p>
<p dir="auto">(In the current beta <strong>Option/Alt + Delete</strong> when node editing will remove the node, the segments and  disconnect the path).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6636</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6636</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 28 Dec 2021 23:27:13 GMT</pubDate></item></channel></rss>
