<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.005]]></title><description><![CDATA[<p dir="auto">This is the first release of VS 1.1 now out of beta.</p>
<h4>Improvements</h4>
<li>Draw Inside to update target if layer selection changes.</li>
<li>Double click on color target widget to open modal color editor.</li>
<li>Improve stroke panel layout.</li>
<li>Action to clear recent file list.</li>
<li>Hold Option (Alt) when clicking flip or rotate icons to duplicate.</li>
<li>Option to not change object color if color mode is changed.</li>
<li>Add *Reveal File" action.</li>
<h4>Fixes</h4>
<li>SVG pasting should retain size if possible.</li>
<li>File Save As dialog resulted in wrong file name on Windows.</li>
<li>Font selection in Recent Fonts list was broken.</li>
<li>Scaling shapes after a reset transform.</li>
<li>Adding unit names in formula evaluation resulted in wrong numbers.</li>
<li>Key modifier (Command / Control) to disable snapping while editing.</li>
<li>Duplicated canvas did not refresh correctly.</li>
<li>Show text baseline in selection.</li>
<li>Deleting text with Cut resulted in wrong cursor positions.</li>
<li>Creating repeaters from menu with a single object did not work.</li>
<li>Option to disable dispersion in symbol sprayer.</li>
<li>Pressing spacebar in Layers panel should activate panning.</li>
<li>Do not snap to the same start / end node in the Node editor.</li>
<li>Refreshing text that resulted from Split Text did not always work.![alt text](image url)</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1314/update-1-1-005</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:30 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1314.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jan 2022 19:14:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.005 on Mon, 03 Jan 2022 20:48:23 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/6782">update 1.1.005</a>:</p>
<blockquote>
<p dir="auto">Hold Option (Alt) when clicking flip or rotate icons to duplicate.</p>
</blockquote>
<p dir="auto">This is great!! I just tried it and it's perfect. Nice shortcut that eliminates a couple steps. Thank you for adding it so quickly</p>
]]></description><link>https://www.vectorstyler.com/forum/post/6785</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/6785</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 03 Jan 2022 20:48:23 GMT</pubDate></item></channel></rss>
