<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 170]]></title><description><![CDATA[<h3>VectorStyler beta 170 release notes</h3>
<li>Improved: additional UI style improvements.</li>
<li>Improved: Big Sur compatibility.</li>
<li>Fixed: crash in with noise transparency modal view and preview enabled.</li>
<li>Fixed: modal noise transparency preview checkbox state should be persistent.</li>
<li>Fixed: text on path converted to curves may move position.</li>
<li>Fixed: creating a text on path after undoing a previous text on path change may cause broken links.</li>
<li>Fixed: highlight shape to show for text on path also.</li>
<li>Fixed: docking horizontal panels under the context panel.</li>
<li>Fixed: horizontal panel docked order to be persistent.</li>
<li>Fixed: rounding corners at large angles with extreme corner size has been improved.</li>
<li>Fixed: show selected cornersize and shape in context panel.</li>
<li>Fixed: gradient midpoint selection from popup gradient views was broken.</li>
<li>Fixed: do not activate mesh tool if mesh transparency creation is cancelled.</li>
<li>Fixed: crash with pattern editor tool when creating new pattern transparency on an object.</li>
<li>Fixed: converting color fonts to curves may change the position of resulting objects.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/132/build-170</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:57 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/132.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Oct 2020 15:27:56 GMT</pubDate><ttl>60</ttl></channel></rss>
