<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.006]]></title><description><![CDATA[<p dir="auto">There was a major regression in the number fields, this build should fix that.</p>
<h4>Fixes</h4>
<li>Regression in number fields with units.</li>
<li>Rendering compositions with transparency in CMYK mode.</li>
<li>Duplicating after duplicated transform crashes.</li>
<li>Flip and rotate buttons retain modifier even if not pressed.</li>
<li>Scaling a rotated object did not adjust the pivot correctly.</li>
<li>Moving down from last line in text did not move after the last character.</li>
<li>Node selection to be kept as local corner selectio. when moving to the corner tool.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1325/update-1-1-006</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:28 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1325.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jan 2022 18:54:17 GMT</pubDate><ttl>60</ttl></channel></rss>
