<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 176]]></title><description><![CDATA[<h3>VectorStyler beta 176 release notes</h3>
<li>Improved: add recent files to MacOS dock menu.</li>
<li>Improved: text on path view content has been rearranged.</li>
<li>Improved: text on path supports text bending mode, with additional bending options.</li>
<li>Improved: add adjustment filter in appearance panel.</li>
<li>Fixed: bending profile preview did not update after selecting a new width profile.</li>
<li>Fixed: noise style should default to relative when used in effects.</li>
<li>Fixed: preview in text on path view did not work.</li>
<li>Fixed: color palette bar popup did not update content if palette was changed.</li>
<li>Fixed: importing pantone color names.</li>
<li>Fixed: option to add as spot color, when selecting a color from an external palette.</li>
<li>Fixed: exporting spot colors to PDF.</li>
<li>Fixed: changes in popover size should not move the bubble pointer.</li>
<li>Fixed: duplicating tiling pattern masks did not copy the mask.</li>
<li>Fixed: noise editor view to add sufficient space for the sliders of each noise type .</li>
<li>Fixed: some CMYK jpeg files were imported in inverted mode.</li>
<li>Fixed: zooming out on color fonts in a CMYK document did not render the fonts correctly.</li>
<li>Fixed: possible crash in font handling when importing some PDF files.</li>
<li>Fixed: regression in PDF import text positioning.</li>
<li>Fixed: possible crash when undocking panels or document tabs.</li>
<li>Fixed: opening CMYK PDF file should create a CMYK document.</li>
<li>Fixed: crash caused by exporting progress view.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/136/build-176</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:18 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/136.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Oct 2020 12:28:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 176 on Sat, 10 Oct 2020 21:25:23 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Awesome! Firing on all cylinders.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/419</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/419</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sat, 10 Oct 2020 21:25:23 GMT</pubDate></item></channel></rss>
