<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 178]]></title><description><![CDATA[<h3>VectorStyler beta 178 release notes</h3>
<li>Improved: Ungroup All action to recursively expand all selected groups.</li>
<li>Fixed: clicking in imported color palettes in the color bar was off by one.</li>
<li>Fixed: automatically mark colors for spot registration in some imported color palettes.</li>
<li>Fixed: crash caused by importing color palettes from ACO format.</li>
<li>Fixed: image effect mask editing may cause a crash if popover is closed while the mask is edited.</li>
<li>Fixed: object style picker to pick colors from selected object after selecting the tool.</li>
<li>Fixed: stroke width list hovering did not cancel when opened from the context panel.</li>
<li>Fixed: better cleanup of stroke expansion with stripes.</li>
<li>Fixed: a bug in importing EPS files containing binary encoded postscript code.</li>
<li>Fixed: converting text on path to curves when bending is used.</li>
<li>Fixed: text on path with bending option while using color fonts.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/137/build-178</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:50:39 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/137.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2020 18:23:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 178 on Thu, 15 Oct 2020 09:58:59 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Yes, resetting was needed, thanks!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/427</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/427</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Thu, 15 Oct 2020 09:58:59 GMT</pubDate></item><item><title><![CDATA[Reply to build 178 on Thu, 15 Oct 2020 08:44:35 GMT]]></title><description><![CDATA[<p dir="auto">Should be in the <em>Object</em> menu.</p>
<p dir="auto">If the menu was customized, this will not show up.<br />
In  that case you need to do a reset to original settings: hold Command+Option+Shift when starting.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/426</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/426</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 15 Oct 2020 08:44:35 GMT</pubDate></item><item><title><![CDATA[Reply to build 178 on Thu, 15 Oct 2020 07:59:33 GMT]]></title><description><![CDATA[<p dir="auto">Where is 'Ungroup All'?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/425</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/425</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Thu, 15 Oct 2020 07:59:33 GMT</pubDate></item></channel></rss>
