<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.008]]></title><description><![CDATA[<p dir="auto">Use "Check for Updates" to update. Automatic update will be enabled a bit later.</p>
<h3>VectorStyler 1.1.008 release notes</h3>
<h4>Improvements</h4>
<li>Added a (customizable) menu when right clicking in the Layers panel.</li>
<li>Layer color indicator and color selection.</li>
<li>Add <em>Artboard Options</em> button to context pane (instead of <em>Create Layer</em>).</li>
<li>Change icon for registration color in Palette panel.</li>
<li>Stronger color palette selection indicators.</li>
<li>Repeater improvements.</li>
<li>Creating blend between grouped shapes.</li>
<li>Do not show saved files in auto recovery.</li>
<li>Create mesh on empty fill should create with null opacity.</li>
<li>Expanding blends (and contours) also inside groups.</li>
<li>Smarter <em>Separate Path</em>.</li>
<li>Order shapes by size in break apart.</li>
<li>Improved divide, exclude and merge of complex shapes.</li>
<li>New <em>Expand Appearance</em> action to separate multiple content of an object.</li>
<li>Use glyph names as object names when converting text to curves.</li>
<li>Drag and drop colors between palettes.</li>
<li>Improved shape builder and shape paint gap detection.</li>
<li>Select and modify multiple stroke width nodes at once.</li>
<li>Option to use frame drawing for text shape creation by default.</li>
<li>Option to reset stroke width profile for new shapes.</li>
<li>Assigned shortcuts to some boolean shape operations.</li>
<h4>Fixes</h4>
<li>Grid shape scaling should keep grid count.</li>
<li>Text on path with styled text required a refresh after changes.</li>
<li>Rigid shapes option in vector brushes should not allow shape stretching.</li>
<li>Paste Below should move pasted item to the layer with selected item (not the current layer).</li>
<li>SVG arrow importing problems.</li>
<li>Registration color must show up on spot plates also.</li>
<li>Symbol selection highlight was not cleared in panel after symbol removal.</li>
<li>Clicking on toolbox button arrow should open immediately (no need for log press).</li>
<li>Use arrow keys for nudging when pressed in the Layers panel.</li>
<li>Prompt to save recovered documents.</li>
<li>Select pattern toling mode in popover view.</li>
<li>Adjusting baseline path of vertical text should keep text direction.</li>
<li>Adding gradient to existing mesh object resulted in wrong content and wrong object position.</li>
<li>Exporting mesh gradient to SVG (flattened to image).</li>
<li>Row and column values for artboard creation of new documents.</li>
<li>Path brush tool cut from shape instead of adding.</li>
<li>Refreshing after offset path.</li>
<li>Using eraser tool on shapes inside groups.</li>
<li>Adjusting stroke profile with a mask form the Stroke Width panel menu.</li>
<li>Stroke alignment with certain control point locations.</li>
<li>Breaking apart transformed text.</li>
<li>Expanding repeater resulted in wrong object positions.</li>
<li>Paste in isolation mode had wrong positions.</li>
<li>Flip horizontal and vertical action using duplicate mode.</li>
<li>Double clicking stroke (or fill) knob in color panel may swap colors.</li>
<li>Non exportable layers were exporting (and non printable were printing).</li>
<li>Expand stroke issues on certain object styles.</li>
<li>Context panel boundary button action was different from the one in the menu.</li>
<li>Create composite boundary when modifier key is held (Option / Alt).</li>
<li>Allow opacity change while in the Node editor.</li>
<li>Single objects were pasted as a group.</li>
<li>Undoing certain expand stroke changes.</li>
<li>Undoing (and redoing) color filters on objects with image effects.</li>
<li>Could not select black or white color in color panel when registration color was used on an object.</li>
<li>Color highlight in color palettes should keep up with current color value.</li>
<li>Resizing or selecting font breaks text shape drawing.</li>
<li>Double click on a shape tool did not always show options of the current shape.</li>
<li>Possible freeze when applying corners to shapes with stray segments.</li>
<li>Gradient transparency rendering problems.</li>
<li>Possible file corruption when using ZStandard compression.</li>
<li>Shape builder states (saved) may cause a crash.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1393/update-1-1-008</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:23 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1393.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Jan 2022 12:53:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.008 on Thu, 20 Jan 2022 16:05:44 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Another terrific list of additions and fixes!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7323</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7323</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 20 Jan 2022 16:05:44 GMT</pubDate></item></channel></rss>
