<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unpredictable changing the value by dragging.]]></title><description><![CDATA[<p dir="auto">As I mentioned before, I have a problem with changing the value by dragging. The possibility itself is great, but the text selection mode with dragging is mixed up very often. I need a few approaches to get the value right. It happens that the cursor should follow perpendicular to the field in order for it to work properly.  I found a workaround for this and use the icons next to them whenever possible. Then no problem. Overall, it makes a bad impression.<br />
I have a problems with changing values with scroll wheel as well. My scroll wheel needs to make 4 steps to change the font for 1 point. With Shift key down it's 9-10 steps, CTRL3-4 steps.  Do we have any setting responsible for that?</p>
<p dir="auto">Do you have similar experiences guys?</p>
<p dir="auto">Edit: I found Number Scrolling Speed  in preferences, and increased it to 300%, helped but have feeling that is not based on mouse wheel steps, but  about some kind of value.  Now every 4th change needs two steps .  100,101,102,103,103,104pt Each value represents one step.</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/1442/unpredictable-changing-the-value-by-dragging</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 02:52:29 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1442.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Jan 2022 17:38:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unpredictable changing the value by dragging. on Fri, 28 Jan 2022 08:51:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> said in [</p>
<blockquote>
<p dir="auto">I have a problems with changing values with scroll wheel as well. My scroll wheel needs to make 4 steps to change the font for 1 point. With Shift key down it's 9-10 steps, CTRL3-4 steps.  Do we have any setting responsible for that?</p>
</blockquote>
<p dir="auto">Yes, I do. I would prefer a value change (a tenth of a unit, a unit or a ten with the  corresponding modifier keys) with only one mouse wheel step (like in Affinity).... @vectoradmin if at all possible of course <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /> thanks in advance.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7523</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7523</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 28 Jan 2022 08:51:20 GMT</pubDate></item></channel></rss>
