<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 185]]></title><description><![CDATA[<h3>VectorStyler beta 185 release notes</h3>
<li>Improved: preferences option to preview shape combine changes when hovering over buttons (<em>Document Editor</em> section, <em>Preview Shape Combine</em>).</li>
<li>Fixed: update color panel when picking colors with Shift, in the color picker.</li>
<li>Fixed: line spacing in text frames when fonts have larger ascents or descents than height (stored in font metrics).</li>
<li>Fixed: show correct TTF font style variation when stored style is shortened.</li>
<li>Fixed: fonts should not default to ornaments variants.</li>
<li>Fixed: font preview can be disabled in preferences (<em>Text Display</em> section, "Preview Fonts in Lists" checkbox).</li>
<li>Fixed: less space at the top of variable font parameter view.</li>
<li>Fixed: primary colors should not be spot in the default color palette.</li>
<li>Fixed: use pure black as default text or stroke color in CMYK documents.</li>
<li>Fixed: do not convert spot color to CMYK when swapping panel state.</li>
<li>Fixed: wrong metric amounts calculated for some variable fonts.</li>
<li>Fixed: some numeric fields did not accept minus sign without number.</li>
<li>Fixed: align numeric fields with sliders in the transform view.</li>
<li>Fixed: shell warp distortion interactive editing handles were in wrong position.</li>
<li>Fixed: size of color panel to be adjusted when swapping panel state.</li>
<li>Fixed: remove extra tint slider from color panel.</li>
<li>Fixed: skip empty colors when importing palettes from ACB files.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/146/build-185</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:20 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/146.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2020 10:09:28 GMT</pubDate><ttl>60</ttl></channel></rss>
