<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.010]]></title><description><![CDATA[<p dir="auto">Manual "Check for Update" is required for now.</p>
<h3>VectorStyler 1.1.010 release notes</h3>
<h4>Improvements</h4>
<li>Exporting CID/CFF fonts to PDF and Postscript.</li>
<li>Exporting Japanese typography to PDF.</li>
<li>Use local miter limit when set.</li>
<li>Add miter limit setting to Stroke panel.</li>
<li>Dividing complex shapes.</li>
<li>Improved merge and union.</li>
<li>Allow object renaming as a double click action.</li>
<li>Layer color indicators.</li>
<li>Activate fill color mode when the shape paint tool is selected.</li>
<li>Improved Navigator panel.</li>
<li>Select same to handle null fill or stroke comparisons also.</li>
<li>Additional options for select same and select by attribute.</li>
<li>Allow Shift+ select with the box marque in the Corner tool.</li>
<li>Importing with drag and drop should position the imported content at the drop location.</li>
<li>Add clipping options to the Layers panel right click menu.</li>
<li>Paste to keep position after small amount of panning.</li>
<li>Adding multiple colors to the color palette.</li>
<li>Gradient tool to work with object groups also.</li>
<li>Increase initial docking drag distance.</li>
<li>Confirm font selection by pressing Enter.</li>
<li>Exit text editing by pressing Escape.</li>
<li>Better slider intervals in Appearance panel for stroke width.</li>
<li>Better shortcuts for Path panel (and Find Previous).</li>
<li>Add node editing actions to the context panel.</li>
<li>Paste shape for shape effect from the panel menu.</li>
<li>Import spot and global colors from ASE files.</li>
<li>Exporting spot colors to EPS and Postscript files.</li>
<li>Warn when replacing existing shortcuts.</li>
<li>Better shortcut for order to back and front actions on Windows.</li>
<li>Allow <em>Intersection Points</em> action for parametric shapes also.</li>
<li>Allow deselecting path node with Shift+click.</li>
<li>Show image effects as adjustments if object has not other content (fill or stroke).</li>
<li>Improved performance when working with complex shapes.</li>
<h4>Fixes</h4>
<li>Possible crash when duplicating objects having an Elastic warp effect.</li>
<li>Possible crash when double clicking on a warped text effect for editing.</li>
<li>Transparent gradients in PDF.</li>
<li>Moving cursor in text did not move to the previous line.</li>
<li>Deleting text was not undone correctly.</li>
<li>Text on path was removed if cannot be shown.</li>
<li>Right click in Layers panel on Windows.</li>
<li>Redirect at intersection in path editor.</li>
<li>Renaming objects did not use numbering correctly.</li>
<li>Drag and drop files into the main view on Windows.</li>
<li>Highlighting the last space in a text using mouse drag.</li>
<li>Separate Path to work on path groups also.</li>
<li>Importing text form PDF resulted in broken text.</li>
<li>Allow the disabling of guideline and grid colors in Document Setup.</li>
<li>Snapping to artboard center to show indicators.</li>
<li>Toolbox popup group opening from arrow should not close it too fast.</li>
<li>Importing fill opacity from SVG files.</li>
<li>Color options in Document Setup were not displayed correctly.</li>
<li>Show a default gradient in the fill popover.</li>
<li>Flip (and scale) with duplication resulted in wrong object copies.</li>
<li>Hiding the color spectrum in the Preferences did not update the color panel.</li>
<li>Disable winding mode for pattern brushes.</li>
<li>Deleting first node in a path, without curvature mode may break the path.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1485/update-1-1-010</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1485.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Feb 2022 09:08:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.010 on Wed, 02 Feb 2022 19:02:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> Every week or two, depending on when @vectoradmin releases an update, the results are always a dramatic improvement; So many issues get fixed, new features added, subtle improvements are great. I agree the layers panel has come a long way. I love whats been happening with the palettes and spot colors, improved boolean operations, etc. I get excited to see the improvements and then jump into deeper things to improve and focus on. Each new build makes the user experience and productivity of VS that much better. Always appreciated @vectoradmin !</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7738</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7738</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 02 Feb 2022 19:02:20 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.010 on Wed, 02 Feb 2022 18:56:38 GMT]]></title><description><![CDATA[<p dir="auto">IKR <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">The layers panel alone now makes me feel warm. It evolved significantly in just a few minor releases a month apart.</p>
<p dir="auto">I really enjoy using VS as a creative tool and also looking at its beautiful interface. Well done @vectoradmin - all included.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7736</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7736</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:56:38 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.010 on Wed, 02 Feb 2022 16:22:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> I can relate. When new builds come out I try to give myself 30 minutes to look it over and check things out before being disciplined and getting back to my daily work. Sometimes it's hard to keep it to 30 minutes! I like to test everything out</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7719</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7719</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 02 Feb 2022 16:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.010 on Wed, 02 Feb 2022 10:55:10 GMT]]></title><description><![CDATA[<p dir="auto">Awesome. But it is getting hard to get some work done on VS release days with my hands in the air and my loud singing. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/7698</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7698</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Wed, 02 Feb 2022 10:55:10 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.010 on Wed, 02 Feb 2022 09:18:41 GMT]]></title><description><![CDATA[<p dir="auto">Waw! massive list of improvements and fixes.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/7697</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/7697</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 02 Feb 2022 09:18:41 GMT</pubDate></item></channel></rss>
