<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[beta 187]]></title><description><![CDATA[<h3>VectorStyler beta 187 release notes</h3>
<li>Improved: reduced object role menu length, using a <em>More Roles...</em> option and a modal view to show all object roles.</li>
<li>Improved: general stability improvements, fixes for submitted crashes.</li>
<li>Improved: added context and property panel content for the artboard tool.</li>
<li>Improved: importing text on path objects from AI files.</li>
<li>Improved: importing artistic brush stretch values from AI files.</li>
<li>Improved: added a gap to the top of the context panel in full screen mode.</li>
<li>Fixed: shift selection modifier in box selection was not working.</li>
<li>Fixed: do not select objects with no fill if the box marque did not intersect the outline.</li>
<li>Fixed: keep cusp control point when using option+click in pen tool.</li>
<li>Fixed: edit envelope effect inside transformed groups.</li>
<li>Fixed: tear-off horizontal toolbox layout.</li>
<li>Fixed: docking toolboxes at the margin regardless of direction.</li>
<li>Fixed: tear-off toolboxes from  group of toolboxes.</li>
<li>Fixed: docked horizontal panel position persistence (after restart).</li>
<li>Fixed: union (and intersection) of overlapping shapes.</li>
<li>Fixed: keep smooth corners when expanding stroke.</li>
<li>Fixed: allow stroke expand when in the node editor.</li>
<li>Fixed: pixel preview of CMYK documents.</li>
<li>Fixed: uniform close button size in document, panel and toolbox.</li>
<li>Fixed: horizontal and vertical panel corner rounding.</li>
<li>Fixed: same toolbox title for docked and tear-off toolboxes.</li>
<li>Fixed: allow docking horizontal panels into vertical panel groups, with automatic layout change.</li>
<li>Fixed: disable modal view opening animation.</li>
<li>Fixed: smaller default node sizes in node (and other) editor.</li>
<li>Fixed: use regular font for artboard labels.</li>
<li>Fixed: remove semicolons from generated color names.</li>
<li>Fixed: activating pen tool using shortcut should also activate the icon in the toolbox.</li>
<li>Fixed: opening shape or image effect editors with multiple effects in the list.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/153/beta-187</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:14 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/153.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Nov 2020 18:47:03 GMT</pubDate><ttl>60</ttl></channel></rss>
