<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.012]]></title><description><![CDATA[<h3>VectorStyler 1.1.012 release notes</h3>
<p dir="auto">Manual "Check for Updates" is required for now.</p>
<p dir="auto">This one has only fixes:</p>
<li>Detecting display resolution from the system.</li>
<li>Shape builder did not recognize all regions.</li>
<li>Handling touching shapes in shape builder.</li>
<li>Regression in Adjustment Effect content.</li>
<li>Image effect rendering with Metal at large resolution.</li>
<li>Exporting large resolution images with image effects.</li>
<li>Brush pressure did not register.</li>
<li>Faster box selection on complex shapes.</li>
<li>Rotation pivot position when repeating or duplicating.</li>
<li>Reset document zoom and position after display resolution change.</li>
<li>Crash when moving objects between views.</li>
<li>Working with grouped objects in the shape builder tool.</li>
<li>Shape paint did not handle composite shapes correctly.</li>
<li>Allow fetching styles from inside complex groups.</li>
<li>Exporting registration and spot colors to EPS.</li>
<li>Font list is closed when using the scrollbar.</li>
<li>Detached toolbox should not stay on top if app is in background.</li>
<li>Palette panel highlight in the first row was clipped.</li>
<li>Searching for unused colors with spot and global colors.</li>
<li>Popover panel resizing resulted in wrong sizes.</li>
<li>Popover panel detaching should not duplicate panels.</li>
<li>Decreasing word spacing using shortcuts should start from the default spacing.</li>
<li>Converting curves to quadratic should keep the tangent direction.</li>
<li>Deleting segments did not keep assigned corners.</li>
<li>Wrong shadows in light theme.</li>
<li>Improved backgrounds in various themes.</li>
<li>Load default theme if the current one is not found.</li>
<li>Hiding spectrum in color panel should not hide it in color popover.</li>
<li>Clicking outside of round color wheel should not select a color.</li>
<li>Improve number field slider alignment.</li>
<li>Blend and contour effect using spot colors.</li>
<li>Path sketch tool adjusted the wrong node.</li>
<li>Allow extending a path with the Pen tool from the starting node (by selecting it with the Node tool).</li>
<li>Use popover sliders for shape vertex count fields.</li>
<li>Document title should be changed after saving recovered files.</li>
<li>Shape builder must skip linked symbols (expand symbol is needed first).</li>
<li>Working with copied objects in shape builder.</li>
<li>Gradient panel and on canvas editor should be updated when changing the color target.</li>
<li>Interactive editing of warp effects should not adjust when releasing the mouse.</li>
<li>Expand Appearance should expand blend and contour effects.</li>
<li>Incorrect naming of duplicated groups.</li>
<li>Possible freeze when opening PDFs containing compressed AI streams.</li>
<li>Expanding a stroke applied on a layer.</li>
<li>Right click context menu may be empty when in the corner editor.</li>
<li>Artboard format was not selected correctly from the context panel.</li>
<li>Regression in intersect clipped groups.</li>
<li>Show and reuse picked color in the color panel.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1544/update-1-1-012</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:20:43 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1544.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Feb 2022 15:41:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 18:04:50 GMT]]></title><description><![CDATA[<p dir="auto">Pressure velocity seems working with pencil tool.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8024</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8024</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 18:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 17:40:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> Shape builder issue resolve. Working great now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8023</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8023</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 17:40:33 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:53:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> When I re install issue in point 3 (can't set stroke size in shape) is gone. but others are still exist.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8021</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8021</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:53:37 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> <img src="/forum/assets/uploads/files/1644424626278-screenshot-25-resized.png" alt="0_1644424625014_Screenshot (25).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/8020</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8020</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:35:22 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Appear now. Uninstalled previous build Fresh Installing now. Will provide what I got after Installing afresh.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8019</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8019</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:35:22 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:32:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> Were these in previous versions, or is it a regression (appeared now)?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8018</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8018</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:32:05 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:29:13 GMT]]></title><description><![CDATA[<p dir="auto">Some Bugs that I encounter:</p>
<ol>
<li>at 100% Interface scalling UI is too large on my 14" screen Laptop. I set to 70%.</li>
<li>Stroke can't be change if pen pressure is on in brush.</li>
<li>when I create a shape fill none, stroke is invisible, visible when I set to around 150/200 at stroke 200 it is like 5.</li>
<li>because I cant set stroke cant confirm pen pressure.</li>
</ol>
]]></description><link>https://www.vectorstyler.com/forum/post/8017</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8017</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:29:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 16:10:59 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/8009">update 1.1.012</a>:</p>
<blockquote>
<p dir="auto">This one has only fixes</p>
</blockquote>
<p dir="auto">These are all terrific fixes! just improving the existing features can be like a new or enhanced feature</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8016</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8016</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 09 Feb 2022 16:10:59 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.012 on Wed, 09 Feb 2022 15:42:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8011</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8011</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Wed, 09 Feb 2022 15:42:41 GMT</pubDate></item></channel></rss>
