<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.016]]></title><description><![CDATA[<h3>VectorStyler 1.1.016 release notes</h3>
<h4>Improvements</h4>
<li>Added option (preferences) to create distortion on tool selection.</li>
<li>Do not adjust effect when releasing mouse.</li>
<li>Always snap to original when duplicating.</li>
<li>Color selector popover should not overlap button or gradient editor knob.</li>
<li>Allow editing gradients on groups.</li>
<li>Option to enable / disable selection of locked objects, when using select by attribute</li>
<h4>Fixes</h4>
<li>General stability fixes.</li>
<li>Better handling of touching shapes in shape builder.</li>
<li>Possible freeze in shape builder.</li>
<li>Faster rendering of aligned outlines.</li>
<li>Exporting drop shadow image effect at large resolutions.</li>
<li>Selecting objects while using the warp tools.</li>
<li>Handling shape centers inside single object reference.</li>
<li>Printing variable fonts to PDF or Postscript to convert to curves.</li>
<li>Issue with importing certain JPEG files.</li>
<li>Drawing lines with pen tool while <em>Show Segment in Pen Tool</em> is enabled.</li>
<li>Copying artboard names from Canvas panel.</li>
<li>Constraining angle (with Shift) in pen tool, while drawing lines.</li>
<li>Possible crash after editing shape drawing options.</li>
<li>Handling empty groups with shapes in Merge operation.</li>
<li>Expanding stroke in blend objects.</li>
<li>Canvas grid may get hidden when switching between documents.</li>
<li>Selecting searched text using the find replace panel.</li>
<li>Importing spot color fills from AI files.</li>
<li>Some black and white BMP files may open in inverted mode.</li>
<li>Do not allow docking of the toolbox next to the tool bar.</li>
<li>Vertical text should not overflow the frame.</li>
<li>Regression in rotating images at certain angles.</li>
<li>Expanding brushes with the rigid shapes option enabled.</li>
<li>In place editing of size lists in preferences.</li>
<li>Resizing shortcuts on Windows.</li>
<li>File creation time should not be erased.</li>
<li>Pasting a copy of a closed path should copy the closing node also.</li>
<li>Text frame content should be visible in outline mode also.</li>
<li>Regression in pixel preview mode.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1578/update-1-1-016</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:46 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1578.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Feb 2022 06:55:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.016 on Tue, 22 Feb 2022 13:50:29 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<p dir="auto">Just in case anybody needs to manually fix the <strong>creation date</strong> of an old file so it matches the correct one in the app's Document Info panel, this can be done in the Terminal app (Mac &gt; Applications &gt; Utilities).</p>
<p dir="auto">So start the Terminal app and type:</p>
<p dir="auto"><strong>touch -t</strong> followed by the correct date and the path to the file (just drag the file from the Finder in the terminal';s window and you get the path to it).</p>
<p dir="auto">The date has the following format YYYYMMDDhhmm:</p>
<blockquote>
<p dir="auto">YYYY - the four digits of the year.<br />
MM - the month of the year, from 01 to 12.<br />
DD - the day of the month, from 01 to 31.<br />
hh - the hour of the day, from 00 to 23.<br />
mm - the minute of the hour, from 00 to 59</p>
</blockquote>
<p dir="auto">…… . .</p>
<p dir="auto">So for example, to change the creation date of the file XYZ.vstyler to 16:15 23rd of October 2021 type this:</p>
<p dir="auto">touch -t 202110231615</p>
<p dir="auto">…then drag the .vstyler file from the Finder in the Terminal window, and press Enter/Return.</p>
<p dir="auto">You can check the result in the Finder, by right-clicking the file and choosing Get Info.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8247</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8247</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 22 Feb 2022 13:50:29 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 15:36:09 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/8202">update 1.1.016</a>:</p>
<blockquote>
<p dir="auto">Selecting objects while using the warp tools.</p>
</blockquote>
<p dir="auto">This is much better now thank you!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8216</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8216</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 21 Feb 2022 15:36:09 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 11:15:09 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Thank you. Fixed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8210</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8210</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 21 Feb 2022 11:15:09 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 10:54:15 GMT]]></title><description><![CDATA[<p dir="auto">Uploaded a fix for the regression in the Windows version. Use "Check for Updates" to update.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8209</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8209</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Feb 2022 10:54:15 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 09:27:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> It is a regression in the new build. I will upload a fix ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8208</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8208</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Feb 2022 09:27:05 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 08:41:00 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin No. It was ok in prev build</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8206</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8206</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 21 Feb 2022 08:41:00 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 08:38:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> Did this occur in previous versions also?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8204</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8204</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Feb 2022 08:38:40 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.016 on Mon, 21 Feb 2022 08:33:03 GMT]]></title><description><![CDATA[<p dir="auto">Nice to see so many fixes and improvements. Just install the update. One issue I see in this build is like in transform panel I can't input the value with number key. Also in tool like elipse I cant input the size with number key.<img src="/forum/assets/uploads/files/1645432375757-screenshot-31-resized.png" alt="1_1645432366667_Screenshot (31).png" class=" img-fluid img-markdown" /> <img src="/forum/assets/uploads/files/1645432375488-screenshot-30-resized.png" alt="0_1645432366666_Screenshot (30).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/8203</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8203</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 21 Feb 2022 08:33:03 GMT</pubDate></item></channel></rss>
