<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.020]]></title><description><![CDATA[<h3>VectorStyler 1.1.020 release notes</h3>
<h4>Fixes</h4>
<li>Regression in creating gradient mesh.</li>
<li>Aligned stroke did not work with variable width profile.</li>
<li>Undoing blend deletion.</li>
<li>Wrong cropping when exporting named layers to PDF.</li>
<li>Accessing Windows task bar in maximized state.</li>
<li>Updating on Windows with unsaved documents.</li>
<li>Undoing certain color palette changes.</li>
<li>Swapping between panels should not resize.</li>
<li>Moving palette colors using drag&amp;drop.</li>
<li>Deleting palette colors using drag&amp;drop unto the panel trash icon.</li>
<li>Deleting palette colors should reset global and spot color indexes correctly.</li>
<li>Preview in gradient slider was broken for spot color gradients.</li>
<li>Adding image or shape effects in the Layers panel did not work on Windows.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1601/update-1-1-020</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:10 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1601.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Feb 2022 06:08:24 GMT</pubDate><ttl>60</ttl></channel></rss>
