<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 192]]></title><description><![CDATA[<h3>VectorStyler beta 192 release notes</h3>
<li>Improved: performance of divide operation on complex shape collections.</li>
<li>Improved: added a shape sketching tool, to automatically cut and merge shapes while drawing.</li>
<li>Improved: added a self avoiding outline option in the stroke settings.</li>
<li>Improved: added a shape effect to create self avoiding paths.</li>
<li>Improved: offset path can create multiple offsets.</li>
<li>Improved: handling of missing fill or outline in the contour effect.</li>
<li>Improved: handling of self intersecting shapes in the shape builder tool.</li>
<li>Improved: do not quit VectorStyler when closing main window.</li>
<li>Improved: fewer buttons in context panel, to accommodate smaller screens.</li>
<li>Improved: show adjustment effect name in appearance panel.</li>
<li>Improved: handling of inside and outside stroke alignment.</li>
<li>Improved: stroke profile on lines and sharp corners did should close properly.</li>
<li>Improved: handling of round corners in stroke profiles.</li>
<li>Improved: smoother slider dragging.</li>
<li>Improved: polygonal spiral context panel was missing.</li>
<li>Improved: character and paragraph view layouts.</li>
<li>Changed: use Option+ modifier in the corner rounding brush tool to reduce corner sizes.</li>
<li>Changed: thinner default UI font, and allow UI font customization.</li>
<li>Fixed: creating stroke profiles on quadratic curve segments.</li>
<li>Fixed: separate composite shapes resulting from divide operation.</li>
<li>Fixed: undo and redo for eraser (and expander) tools.</li>
<li>Fixed: do not unlink image after cutting to the clipboard (image will be needed).</li>
<li>Fixed: shadows and highlights filter popover view was too large.</li>
<li>Fixed: changing paragraph alignment when a text frame is selected.</li>
<li>Fixed: outline width inside a group was not taken into account when refreshing.</li>
<li>Fixed: font size in undo popup and report views.</li>
<li>Fixed: do not group objects when deleting effect.</li>
<li>Fixed: new layer name should be created based on sibling layer names.</li>
<li>Fixed: handling of self intersecting paths with stripes.</li>
<li>Fixed: stroke expansion issues with some shapes, when the stroke is aligned outside or inside.</li>
<li>Fixed: stroke alignment issues on some shapes.</li>
<li>Fixed: expanding overlapping stroke with dashes should merge overlaps.</li>
<li>Fixed: variable with profile should work globally when using both stripes and dashes.</li>
<li>Fixed: expanding stroke inside groups.</li>
<li>Fixed: performance of expanding stroke containing combinations of variable widths, stripes and dashes.</li>
<li>Fixed: do not activate mesh too if mesh creation is canceled.</li>
<li>Fixed: possible crash when clicking on an image effect icon in the appearance panel.</li>
<li>Fixed: improved stability of some operations in the user interface.</li>
<li>Fixed: contour tool should not adjust the contour when clicking for selection.</li>
<li>Fixed: plain text variables did not always update when changed.</li>
<li>Fixed: showing outlined text at large zooms.</li>
<li>Fixed: improvements for UI layouts on Big Sur.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/169/build-192</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:21 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/169.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Dec 2020 11:30:10 GMT</pubDate><ttl>60</ttl></channel></rss>
