<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.024]]></title><description><![CDATA[<h3>VectorStyler 1.1.024 release notes</h3>
<h4>New</h4>
<li>Finding shapes with smaller area using the magic wand tool and panel.</li>
<li>New action (in Object - Shape) <em>Select Shape</em> to copy (or link) shape between selected objects.</li>
<li>New action (in Object - Shape) to cut paths at intersecting points.</li>
<li>New action (in Object - Shape) to split paths at cusp nodes.</li>
<li>Added new path intersection actions to the Path panel.</li>
<li>Proportional scaling option in Alignment panel menu when aligning size.</li>
<li>Quick opacity setting of selected objects using the number keys (optional, can be disabled in preferences).</li>
<li>Add option to make images linked in the Link panel.</li>
<li>Relinking an image from a file should adjust the clipping shape proportions.</li>
<li>Double clicking the ruler should open the <em>Guidelines</em> panel.</li>
<li>New option: <em>Preferences -&gt; Document Editor -&gt; Context Menu on Mouse Release</em>, to show context menu when the right mouse button is released.</li>
<li>Added a proportional size lock button in <em>Shape</em> panel.</li>
<li>Added a <em>Transform Stroke</em> option for objects (Appearance panel and Object Options) to enable stroke transformations on all outlines inside the object (groups or layers also).</li>
<li>Second click on the cusp node icon will retract control points.</li>
<li>Added <em>Expand Appearance</em> to the default tool bar.</li>
<li>Shape editor to delete the object if no noxe is selected.</li>
<li>Double click on existing node to create a new node at the middle of the segment.</li>
<li>Added shape builder options to the context bar.</li>
<li>Added new actions for some of the snapping options.</li>
<li>Added a new action to the tool bar for restricting snapping to the selected objects.</li>
<li>Added an icon tow to the <em>Grid</em> panel with common actions.</li>
<li>Tapered adjustment of offset distances using a transfer function in offset path.</li>
<li>Select and replace document palette on Document Options -&gt; Color view.</li>
<li>Added a new shape effect: <em>Node Bump</em>.</li>
<li>Added a new tool to use only for selection and moving of objects.</li>
<h4>Improved</h4>
<li>Repeater performance for all geometries.</li>
<li>Set repeater shape expand amount from panel also.</li>
<li>Allow larger number of symbols in scatter brush.</li>
<li>Merge and divide precision with overlapping shapes.</li>
<li>Improved speed of divide and merge.</li>
<li>Symbol selection for stamp and spray tools should persist.</li>
<li>Select any object as a symbol while in stamp and spray tools with Shift+Click.</li>
<li>Show symbol spray and stamp tool options in context panel.</li>
<li>Optional setting of artboard position, when creating new artboards with <em>Create Artboard</em>.</li>
<li>Allow moving the whole layer if selected in the Layers panel.</li>
<li>Better indication when path is closed with the Pen tool.</li>
<li>Liquify tool should also work if a shape node is not covered.</li>
<li><em>Move Inside Last</em> action should also adjust object transform if moved into a transformed group.</li>
<li>Shape builder performance.</li>
<li>Do not select null and registration colors when selecting unused color in the color palette.</li>
<li>Use Shift+ modifier in path brush and eraser tool to constrain drawing to a line.</li>
<li>Option to enable unrestricted number precision in number editors.</li>
<li>Option to allow default brush to be a solid stroke (option in <em>Brushes</em> panel menu).</li>
<li>Fetching default gradient color in gradient tool from the solid color of the selection.</li>
<li>Show dimensions of artboards in artboard size preset menus.</li>
<li>Renamed the <em>Content Links</em> panel with <em>Links</em>.</li>
<li>Renamed the <em>Snapshot Name</em> menu to <em>New Snapshot</em>.</li>
<li>Layers panel: hold Control to set visibility or locking for all objects inside a layer or group.</li>
<li>Layers panel: hold Option (Alt) to set visibility or locking for all objects at the same level as the clicked object.</li>
<li>When opening <em>Object Options</em> allow immediate typing of the object name.</li>
<li>Object placement when drawing new objects to allow for correct <em>after</em> and <em>before</em> insertion modes.</li>
<li>Added preferences option to disabled host accelerated color conversions.</li>
<li>Allow Shift+ modifier in Magic wand tool to add modify existing selection.</li>
<h4>Fixed</h4>
<li>Setting cusp node in Pen tool when closing the path.</li>
<li>Separate shapes after merge and divide.</li>
<li>Rendering aligned stroke with scaling.</li>
<li>Extra artboard was added by a root canvas.</li>
<li>Canvas roles were not working.</li>
<li>Object and Canvas role menus were not working on Windows.</li>
<li>Popup menu selection issues on Windows.</li>
<li>Creating cusp nodes in the Pen tool using Option (Alt) modifier.</li>
<li>Allow snapping of quadratic segment handles.</li>
<li>Positioning objects when coping and pasting inside transformed layers.</li>
<li>Regression in expanding clipped groups.</li>
<li>Path brush error in complex shapes.</li>
<li>Updating top down vertical rulers when scrolling.</li>
<li>Positions were wrong when splitting aligned text.</li>
<li>Double clicking on text resulted in wrong cursor positions.</li>
<li>Expanding symbols should remove the object role.</li>
<li>Regression in selecting similar fill content.</li>
<li>Full screen mode on Windows with auto hiding task bar.</li>
<li>Printing resulted in an extra artboard.</li>
<li>Image effect boundary when using twirl distortion.</li>
<li>Image effect boundary when using concentric warp distortion.</li>
<li>Customized and large toolboxes may show with wrong size.</li>
<li>Possible crash when flipping gradients containing mixed process and spot colors.</li>
<li>Linking certain image types resulted in wrong size.</li>
<li>Moving, scaling and rotating inside transformed groups.</li>
<li>Display the rope indicator in bath brush and eraser tools.</li>
<li>Pasting text into newly sized text shape.</li>
<li>Possible crash when browsing the font name list.</li>
<li>Shape editor for parametric shapes (rectangle, ellipse, etc) did not load in some cases.</li>
<li>Text positioning when importing AI files.</li>
<li>Printing CMYK documents with Xerox printer drivers.</li>
<li>Importing PDF files with AI embedded data.</li>
<li>Grid editor preview and undo redo did not refresh grid on the screen.</li>
<li>Broken content when importing certain JPEG images.</li>
<li>Possible crash when adding image effects in the Appearance panel.</li>
<li>Appearance panel was not updated when in background.</li>
<li>Exporting PNG (or other image) formats did not open preview with <em>Open Exported File</em> enabled.</li>
<li>Importing older version AI files with images.</li>
<li>Gradient on stroke bug when using a start cap attribute other than flat.</li>
<li>Allow empty spacing field in Alignment panel.</li>
<li>Palette presets to be accessible in Preset Manager.</li>
<li>Show preset name in palette panel when using palette presets.</li>
<li>Palette preset panels to be persistent when restarting.</li>
<li>Possible crash when using offset path with multiple offsets.</li>
<li>Expanding stroke inside transformed groups.</li>
<li>Expanding transformed vector brushes.</li>
<li>Text labeling (numbers and bullets) options were not selected correctly in the paragraph options view.</li>
<li>Better selection with mouse click for overlapping outlines.</li>
<li>Windows key was handled incorrectly.</li>
<li>Inconsistent corner resizing for the first node on a closed shape.</li>
<li>For preview in font name list was not aligned correctly.</li>
<li>Bug in OpenGL display mode when using calibrated RGB color modes.</li>
<li>Do not include punctuations when highlighting words with double clicks.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1696/update-1-1-024</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1696.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Mar 2022 06:11:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.024 on Mon, 21 Mar 2022 19:31:13 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin This is an incredible list of improvements, fixes and new additions. Thank you so much for listening to the ideas and making all the changes. I say it often, but VS becomes a more attractive, stable and powerful program with each build update.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9266</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9266</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 21 Mar 2022 19:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.024 on Mon, 21 Mar 2022 12:43:56 GMT]]></title><description><![CDATA[<p dir="auto">The closing with Cusp node in the Pen tool seems to be not working yet.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9139</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9139</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Mar 2022 12:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.024 on Mon, 21 Mar 2022 11:09:33 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Awesome! And thank you for 'Cut at Cusp Nodes'. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
<p dir="auto">A possible improvement (if not too difficult) would be avoiding to split the path at nodes that are marked as cusp but their handles are exactly the same length and are opposite each other so the node is in fact a symmetrical node.</p>
<p dir="auto">Thanks again!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9119</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9119</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Mon, 21 Mar 2022 11:09:33 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.024 on Mon, 21 Mar 2022 12:44:04 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately, there is a regression in scrolling number fields with the keyboard arrow keys (due to some new precision settings).</p>
<p dir="auto">Workaround: go to Preferences -&gt; Number Editors, and enable <em>Limit Precision</em>.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/8961</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/8961</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 21 Mar 2022 12:44:04 GMT</pubDate></item></channel></rss>
