<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 193]]></title><description><![CDATA[<h3>VectorStyler beta 193 release notes</h3>
<li>Improved: context panel should contain all object properties, even with no selected, when the brush tool is active.</li>
<li>Improved: create closed shapes with the sketch tool, when sketch is self intersecting.</li>
<li>Improved: importing AI brush styles and exporting as presets.</li>
<li>Improved: disable large preview in Layers panel options.</li>
<li>Improved: added a destructive <em>Offset Path</em> command to create offsets from selected shapes.</li>
<li>Changed: use the Tab key in the path sketch tool to swap between line and freehand modes (Space is for panning).</li>
<li>Fixed: bug in Symbols panel, did not list created symbols, only objects with symbol role.</li>
<li>Fixed: multiple outline offsetting and stroke stripe issues.</li>
<li>Fixed: inner or outer stroke alignment issues with some shapes.</li>
<li>Fixed: gradient on stroke regressions.</li>
<li>Fixed: changing stroke, brush width and font size values in preferences.</li>
<li>Fixed: crash with when accessing OpenType features in some fonts.</li>
<li>Fixed: crash when trying to blend shapes with small number of segments.</li>
<li>Fixed: do not smooth nodes when switching to node editor with the Command+ key.</li>
<li>Fixed: image content rotation angle should be selectable from the drop down list.</li>
<li>Fixed: moving artboards with partial group overlapping.</li>
<li>Fixed: possible crash caused by hovering selection.</li>
<li>Fixed: do not store current brush in workspace, complex brush may slow down startup and exit.</li>
<li>Fixed: combining multiple shapes with groups.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/176/build-193</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:16 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/176.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Dec 2020 18:12:37 GMT</pubDate><ttl>60</ttl></channel></rss>
