<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.026]]></title><description><![CDATA[<h3>VectorStyler 1.1.026 release notes</h3>
<h4>Fixed</h4>
<li>Using pure spot color gradients and exporting to PDF.</li>
<li>Allow line constraining with Shift+ before pressign the mouse in the eraser, knife and path brush tools.</li>
<li>Regression in repeater expand.</li>
<li>Regression in symbol tools.</li>
<li>Hide selection when holding space key.</li>
<li>Deselect node in Node editor when clicking away.</li>
<li>Refresh issues when moving or transforming groups containing composite groups.</li>
<li>Color palette panel tool tips on Windows.</li>
<li>Clicking on sub menu names should not exit the menu.</li>
<li>Shortcut editor view may freeze when clicking away from an active shortcut field.</li>
<li>Select corner size from context panel, only for selected corners.</li>
<li>Control backspace to delete word on Windows in name editors.</li>
<li>Select all in Layers panel opened name editor should select text.</li>
<li>Path closing indicator in Pen tool.</li>
<li>Selecting the clipping shape of a group nested inside a transformed group.</li>
<li>Selecting a font did not add it to the recent font list.</li>
<li>Canvas role for Object Style was not applied correctly.</li>
<li>Opened Styles panel may break other panel updating (for example: Layers panel).</li>
<li>Changing object style using object role did not propagate in some cases.</li>
<li>Move inside last in transformed groups did not position and transform correctly.</li>
<li>Undoing moving inside did not refresh correctly.</li>
<li>Combine operations inside transformed group did not consider parent transforms.</li>
<li>Crash when selecting cusp node corner for open path ending nodes.</li>
<li>Pasting screen shot image from clipboard on Windows.</li>
<li>Code page for tool tips was wrong on Windows.</li>
<li>Selecting object shape to keep the visual center of objects.</li>
<li>Setting the snapshot name to setup default name from current time.</li>
<li>Using both canvas and object roles may create conflicts in the Styles panel.</li>
<li>Using multiple roles on a single object to list them correctly in the Styles panel.</li>
<li>Changes to shape style override did not propagate correctly.</li>
<li>Shape styles list did not open in override panel for shape styles.</li>
<li>Undo and redo after merging certain transformed groups of complex shapes.</li>
<li>Copy and paste to keep object position if object is visible inside the current view.</li>
<li>Snapping restriction button to be checkable, clearing restriction when unchecked.</li>
<li>Add null and registration color to selected document palette.</li>
<li>Adding symbols with the symbol spray tool inside transformed symbol sets placed them in wrong positions.</li>
<li>Symbol tinting brush did not expand symbols correctly.</li>
<li>Possible crash when opening AI files with embedded images.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1789/update-1-1-026</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:10 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1789.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Mar 2022 15:38:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.026 on Mon, 28 Mar 2022 21:37:18 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin On my Windows machines the shortcut I manually add to the taskbar is removed when I update VS. I have seen other apps do the same. I don't use Windows much anymore so I start it from the start menu instead and forgot to report it.</p>
<p dir="auto">I remember some instances (other programs) where the shortcut used a more technical reference to the program rather than the file path and thus was removed when the updated program got a new technical reference during setup.</p>
<p dir="auto">Looks like the same is happening there: "wrong parameter" means the reference is no longer valid.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9767</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9767</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Mon, 28 Mar 2022 21:37:18 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.026 on Sun, 27 Mar 2022 16:30:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> I just updated here on a Windows 10, and the previous taskbar shortcut is working.<br />
Could it be that VS ended up in a different folder?</p>
<p dir="auto">I think the quick fix now is to recreate the taskbar shortcut.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9661</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9661</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 27 Mar 2022 16:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.026 on Sun, 27 Mar 2022 16:31:38 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin After update when I click taskbar shortcut I created earlier before the update shows this message</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1648397837583-screenshot-2022-03-27-214639-resized.png" alt="0_1648397835022_Screenshot 2022-03-27 214639.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Update: after restart pc Shortcut completely removed</p>
]]></description><link>https://www.vectorstyler.com/forum/post/9659</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/9659</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Sun, 27 Mar 2022 16:31:38 GMT</pubDate></item></channel></rss>
