<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.030]]></title><description><![CDATA[<p dir="auto">This build contains mostly fixes, and some small improvements.</p>
<h3>VectorStyler 1.1.030 release notes</h3>
<li>Control + Backspace deactivated the editor on MacOS.</li>
<li>Skip selected closed paths when using the Pen tool.</li>
<li>Additional keep color mode issues are fixed.</li>
<li>Closing path with the Node tool resulted in a smooth node.</li>
<li>Paste Inside raw text should not replace the selected shape.</li>
<li>Deleting a word should position the cursor correctly.</li>
<li>Path brush improvements.</li>
<li>Do not show control point handle in Pen tool if it was not dragged.</li>
<li>Pen tool path closing issues.</li>
<li>Editing and adding image effects on locked layers should result in an alert.</li>
<li>Image display while drawing shapes.</li>
<li>Wrong path highlight display on certain shapes with stroke.</li>
<li>Remove Path from blend panel.</li>
<li>Keep minified panels when restarting app.</li>
<li>Delete subpath at the second delete action.</li>
<li>Clean stray segments and points inside groups also.</li>
<li>Added a node clicking tolerance option.</li>
<li>Using Alt+ modifier on shape operation from context bar should create composite shapes.</li>
<li>Composite shape was not updated correctly in the Layers panel.</li>
<li>Glitch in the Opacity Values and Mask drop-down menu.</li>
<li>Expanding transformed stroke.</li>
<li>Reference image pixel movement when adding nodes or editing them.</li>
<li>Possible crash with certain tinted vector brushes.</li>
<li>Problems with inputting diacritic marks with AltGr+ key on Windows.</li>
<li>Cusp node control point retraction shortcut resulted in wrong shape.</li>
<li>Possible crash when importing EPS or PS files.</li>
<li>Click on shapeless repeater did not always select it.</li>
<li>Color popover in Layers panel should not close when clicking inside (Windows).</li>
<li>Do not paste inside locked Layers.</li>
<li>Drawing shapes above a locked layer did not always draw.</li>
<li>Paste Inside did not work when Draw Above or Behind were active.</li>
<li>Improved performance of repeaters when colorization is used.</li>
<li>Undoing expand stroke with fill above the stroke.</li>
<li>Option to smooth out edges in image trace.</li>
<li>Artboard margins were not selected when creating new document with multiple artboards.</li>
<li>Number keys should be used as shortcuts while in the Node tool.</li>
<li>Scaling multiple selected and rotated shapes resulted in wrong positions and scale.</li>
<li>Added as sort by hue and brightness to the color palette.</li>
<li>On MacOS, the select folder panel to use the Select label for the confirm button.</li>
<li>Reordered the icons in the Path panel to match the order in the context panel.</li>
<li>Adjusting the blur handle of the drop shadow effect resulted in the wrong refresh.</li>
<li>Exporting image effects to PDF.</li>
<li>Pattern brush should handle spacing correctly for closed shapes.</li>
<li>Added options to show PDF only blend modes.</li>
<li>Spike effects should result in cusp nodes.</li>
<li>Changing multiple segments to lines should result in cusp nodes.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1890/update-1-1-030</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1890.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Apr 2022 16:04:59 GMT</pubDate><ttl>60</ttl></channel></rss>
