<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alt modifier key for lasso selection]]></title><description><![CDATA[<p dir="auto">Is Alt modifier key activate lasso selection tool? And if yes I think there a bug in Alt modifier key to select objects. When I tried to select object with Alt Modifier key it select everything. <a href="https://recordit.co/0523qv7tlk" rel="nofollow ugc">See the recording</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/1905/alt-modifier-key-for-lasso-selection</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 03:35:12 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1905.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Apr 2022 10:03:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Alt modifier key for lasso selection on Mon, 18 Apr 2022 15:01:03 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Yes, I did but it select all. <a href="https://recordit.co/lbnrmkPyVf" rel="nofollow ugc">Here is the recording</a>. When I select lasso tool it works. But when I use Alt modifier it select all the objects.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10385</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10385</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 18 Apr 2022 15:01:03 GMT</pubDate></item><item><title><![CDATA[Reply to Alt modifier key for lasso selection on Mon, 18 Apr 2022 14:14:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> I check what is going on here. There is a condition, where the open lasso shape will select only objects that are crossed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10382</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10382</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 18 Apr 2022 14:14:58 GMT</pubDate></item><item><title><![CDATA[Reply to Alt modifier key for lasso selection on Mon, 18 Apr 2022 12:03:01 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Yes 'Intersecting selection' is enabled in select menu. Still Alt modifier doesn't select the intersecting object instead it select all the object inside.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10379</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10379</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 18 Apr 2022 12:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to Alt modifier key for lasso selection on Mon, 18 Apr 2022 11:27:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> Is "Intersecting Selection" in the Select menu enabled? If so, the objects intersecting the lasso are all selected. Otherwise only objects inside the lasso are selected.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10377</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10377</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 18 Apr 2022 11:27:37 GMT</pubDate></item></channel></rss>
