<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 194]]></title><description><![CDATA[<h3>VectorStyler beta 194 release notes</h3>
<li>Improved: <em>dynamic</em> mode to the pencil tool (context panel), erase path sections between intersections while holding the Shift key.</li>
<li>Improved: when holding the Shift key in the <em>erase</em> tool, parts of paths between intersections can be erased.</li>
<li>Improved: added non linear slider scale for numeric fields.</li>
<li>Improved: added a <em>Break Apart</em> button to the context panel when the eraser, knife and pencil tool are active.</li>
<li>Improved: also open AI files are presets also from the Panels -&gt; Presets -&gt; Open Preset File command.</li>
<li>Improved: faster opening and handling of AI files as presets.</li>
<li>Improved: show only brush presets when opening an AI file as a brush preset file.</li>
<li>Improved: allow preset group hiding in imported presets also.</li>
<li>Improved: added a <em>Close</em> button to each panel leaf, visible only when hovering.</li>
<li>Improved: added a rotate handle mode option for the transform tool (Preferences -&gt; Adjustments -&gt; Selection Box).</li>
<li>Improved: recover artboard sizes when opening multi page PDF files.</li>
<li>Improved: merge the various pointer selection tools into one tool, with options in the context panel.</li>
<li>Improved: merge the pressure sensitive pencil and brush tools into the pencil and brush tool.</li>
<li>Improved: added undo/redo detail option, while editing shape (and image) effects (Preferences -&gt; Changing Options -&gt; Merge Shape / Image Effect Undo).</li>
<li>Improved: zoom to artboard where the last selection was made.</li>
<li>Improved: open modal transform view when pressing the return key in scale, skew and rotate tools.</li>
<li>Improved: change all text flow font when selecting font on a whole text frame.</li>
<li>Improved: merge two open paths into a single open path, when common intersecting locations are close (instead of creating a closed path).</li>
<li>Fixed: use the current content selection of Appearance panel when editing and creating shape effects interactively.</li>
<li>Fixed: do not clear the current content selection when deactivating the Appearance panel.</li>
<li>Fixed: possible crash when importing scatter brush presets from AI files.</li>
<li>Fixed: show open file view to select preset when the first button in the panel bottom is pressed.</li>
<li>Fixed: printing to PDF placed the markers at the wrong positions.</li>
<li>Fixed: problem with whitespace size in some variable fonts.</li>
<li>Fixed: switching to node editor with Command key did not work properly.</li>
<li>Fixed: text linking tool should not create a solid line frame.</li>
<li>Fixed: clicking on highlighted font name did not always select the font.</li>
<li>Fixed: holding the Shift key should constrain movement direction in the node tool also.</li>
<li>Fixed: copy pasting inside multiple object did not retain position.</li>
<li>Fixed: blend objects were not reset correctly on certain changes.</li>
<li>Fixed: docking panels on the window margin did not always reset their position correctly.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/191/build-194</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/191.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Dec 2020 15:20:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 194 on Mon, 21 Dec 2020 23:20:01 GMT]]></title><description><![CDATA[<p dir="auto">Amazing to see how quickly you put our feedback into this update!! Great work, I can't wait to try it!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/668</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/668</guid><dc:creator><![CDATA[postdes]]></dc:creator><pubDate>Mon, 21 Dec 2020 23:20:01 GMT</pubDate></item></channel></rss>
