<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.032]]></title><description><![CDATA[<h3>VectorStyler 1.1.032 release notes</h3>
<li>Regression in image opacity rendering.</li>
<li>Path brush may result in multiple copies of some shapes.</li>
<li>Brush options to have local settings for stabilizer.</li>
<li>Knife tool regression, did not cut path correctly.</li>
<li>Regression when excluding using open paths.</li>
<li>Options to separate paths after using knife or eraser tools.</li>
<li>Brush panel should update from solid stroke also.</li>
<li>Keep selection mode for transform tool is not kept between multiple documents.</li>
<li>Set fill below object content.</li>
<li>Extend path from the starting node using the Pen tool.</li>
<li>Persistent settings in Navigator panel.</li>
<li>Copy and paste while using a shape distortion tool.</li>
<li>Adjustment effect masking.</li>
<li>Use Control modifier to automatically close lasso selection.</li>
<li>Show file name in alert when opening missing file.</li>
<li>Stroke rendering with matching stroke width and object size.</li>
<li>Automatically highlight text input in some modal views.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1916/update-1-1-032</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1916.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Apr 2022 18:39:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.032 on Tue, 19 Apr 2022 21:15:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> No, it's a fix for this issue: <a href="https://recordit.co/L11CBNccPE" rel="nofollow ugc">https://recordit.co/L11CBNccPE</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/10459</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10459</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 19 Apr 2022 21:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.032 on Tue, 19 Apr 2022 20:34:17 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin  I always appreciate the updates! thank you</p>
<p dir="auto">@vectoradmin said in <a href="/forum/post/10455">update 1.1.032</a>:</p>
<blockquote>
<p dir="auto">Extend path from the starting node using the Pen tool.</p>
</blockquote>
<p dir="auto">Is this a fix for the "false start" that would occur at times when trying to begin a new pen tool path? It would skip the first node placement and start with the next. I hope that is the case because it has not been happening in  build 32</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10457</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10457</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 19 Apr 2022 20:34:17 GMT</pubDate></item></channel></rss>
