<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.036]]></title><description><![CDATA[<h3>VectorStyler 1.1.036 release notes</h3>
<li>Using space key to temporarily switch to panning may break in some cases.</li>
<li>Deleting the last object inside a transparency mask should keep the isolation mode correctly.</li>
<li>Offset path to place results underneath the selected objects.</li>
<li>Disable stroke width in Offset Path if stroke style is not enabled.</li>
<li>Regression in paste inside.</li>
<li>Guidelines should snap to grid.</li>
<li>Blending between solid and variable width stroke.</li>
<li>Regression in adjustment layer effect rendering.</li>
<li>Pen tool to indicate node selection when hovering over the node.</li>
<li>Clipping of objects with image effects may render with wrong masks.</li>
<li>Font list opened from character panel closes after scrolling.</li>
<li>Adding gradient to object with no fill style.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/1958/update-1-1-036</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:16 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/1958.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Apr 2022 18:54:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.036 on Wed, 27 Apr 2022 19:03:53 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin Thank you for the update! space key for panning is working great now - I'll let you know if I run into issues with the alt/option key, but initial tests also working properly for me now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/10709</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/10709</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 27 Apr 2022 19:03:53 GMT</pubDate></item></channel></rss>
