<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 198]]></title><description><![CDATA[<p dir="auto">(changes accumulated over several smaller builds)</p>
<h3>VectorStyler beta 198 release notes</h3>
<li>Fixed on Windows: single key shortcut handling on.</li>
<li>Fixed on Windows: holding modifier keys on slowed down interaction.</li>
<li>Fixed on Windows: maximizing window covered the task bar, and the menu bar was moved outside of the screen area.</li>
<li>Improved: new copy paste appearance to copy and paste all attributes, not just fill or stroke style.</li>
<li>Improved: use last export settings, if document has no stored export settings.</li>
<li>Improved: use current selected color in gradient editor, when creating new gradients.</li>
<li>Improved: resizable panel docking on the window side to be placed into the available area.</li>
<li>Fixed: could not disable intersecting selection mode.</li>
<li>Fixed: mesh transparency mode did not render.</li>
<li>Fixed: could not remove mesh transparency mode, while in the mesh editor.</li>
<li>Fixed: object positions were wrong when creating and editing mask objects (Drawing).</li>
<li>Fixed: canceling mesh transparency mode should return the selection to the current mode.</li>
<li>Fixed: preset menu heading labels should display the preset groups only.</li>
<li>Fixed: there were two <em>None</em> modes in the transparency panel drop down.</li>
<li>Fixed: add breadcrumbs to hierarchical preset menus.</li>
<li>Fixed: show name of the current transparency preset.</li>
<li>Fixed: remove opacity from blend mode and similar drop down menus.</li>
<li>Fixed: segment eraser mode did not handle well merging of shapes.</li>
<li>Fixed: segment eraser mode to erase non intersecting closed shapes also.</li>
<li>Fixed: better cursor handling in interactive editors.</li>
<li>Fixed: use check box for merging option in segment eraser mode.</li>
<li>Fixed: persistent pointer tool mode.</li>
<li>Fixed: faster merging of large number of shapes.</li>
<li>Fixed: regression in rigid warp editor blocked anchor node creation.</li>
<li>Fixed: add pressure options button to the eraser tool options.</li>
<li>Fixed: in node editor, with multiple selected objects, do not delete object of no node is selected in it.</li>
<li>Fixed: keep image effects when ungrouping objects.</li>
<li>Fixed: deleting images inside a group required a refresh.</li>
<li>Fixed: problems when copy pasting image objects inside the same document.</li>
<li>Fixed: copy paste style to place style correctly on groups.</li>
<li>Fixed: bristle brush endings on closed shapes should match.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/199/build-198</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:13 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/199.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Dec 2020 07:19:12 GMT</pubDate><ttl>60</ttl></channel></rss>
