<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.040]]></title><description><![CDATA[<h3>VectorStyler 1.1.040 release notes</h3>
<li>Windows compatibility improvements.</li>
<li>Exporting certain OpenType fonts to PDF.</li>
<li>Picking spot color from external palettes in modal views also.</li>
<li>Show color palette name in color palette bar as a tooltip in the title knob.</li>
<li>Delete multiple selected colors from a palette.</li>
<li>Undoing node alignment.</li>
<li>Default settings for multiple line text on path when adjusting baseline path.</li>
<li>Display option changes to be used as defaults.</li>
<li>Number field expressions should work with all units.</li>
<li>Undo, redo and preview of paragraph labeling options.</li>
<li>Gradient mask editor to work with selected content type from the Appearance panel.</li>
<li>Deleting a cusp node should not result in a curved segment.</li>
<li>CMYK group transparency rendering.</li>
<li>Panels may end up under the menu bar on MacOS.</li>
<li>Reopening a closed toolbox should dock it automatically on th left.</li>
<li>Scrolling in preferences list should not display the scroll indicator.</li>
<li>Crash when clicking preview in the stroke width editor.</li>
<li>Sub path selection bounding box when switching to transform tool.</li>
<li>Shape corner effect added on top of Crossing Gap effect skipped some corners.</li>
<li>Swap below / above values in Crossing Gap shape effect.</li>
<li>Pivot of group should not move when duplicating with rotation.</li>
<li>Appearance panel did not show and edit styles from the selected text.</li>
<li>Regression in using the space key for Kana conversion.</li>
<li>Deleting artboards in the Canvas panel did not update the selection correctly.</li>
<li>Duplicating artboards in the Canvas panel.</li>
<li>Moving multiple selected nodes from different paths or lines did not undo correctly.</li>
<li>Editing corners in composite shapes.</li>
<li>Smoothness option was not used in path sketch tool.</li>
<li>Color slider mode may change when switching to stroke mode.</li>
<li>Automatically snap to selected objects in drawing tools.</li>
<li>Selecting character style presets in the character panel.</li>
<li>Alphabetical listing of shape effect tools.</li>
<li>Typography panel did not always update when selected font changed.</li>
<li>UI scaling did not scale drop down lists correctly.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2030/update-1-1-040</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:16 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2030.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 May 2022 18:37:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.040 on Wed, 18 May 2022 03:13:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Many thanks for all the fixes you implemented!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11235</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11235</guid><dc:creator><![CDATA[Victor Vector]]></dc:creator><pubDate>Wed, 18 May 2022 03:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.040 on Tue, 17 May 2022 19:34:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/11216">update 1.1.040</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Thanks that you solve it. This issue was there from a very long time.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11231</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11231</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Tue, 17 May 2022 19:34:49 GMT</pubDate></item></channel></rss>
