<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.041]]></title><description><![CDATA[<p dir="auto">There were some regressions, and issues that required an additional build.</p>
<h3>VectorStyler 1.1.041 release notes</h3>
<li>Copying text after vectors did not clear the clipboard.</li>
<li>Possible text movement when pasting symbols inside text.</li>
<li>Do not show scroll indicator in History panel.</li>
<li>Automatically close opened paths in PDF import.</li>
<li>Pattern mask tool to work with Appearance panel when editing transparency mask.</li>
<li>Deleting a node should not leave other nodes selected.</li>
<li>Inserting nodes with the first node selected.</li>
<li>Adding gradient to a group using the gradient tool should place the fill above the group content.</li>
<li>Pen tool segment preview after undoing a change.</li>
<li>Closing path with the pen tool should not result in short control points.</li>
<li>Hide some transform and corner control points when a shape is small.</li>
<li>Hide object styling when repeater is used on text object.</li>
<li>Drag and drop object from the Layers panel onto the Repeater panel.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2043/update-1-1-041</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:16:17 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2043.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 May 2022 17:37:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.041 on Mon, 23 May 2022 08:57:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> I think in this case the result is not that important, the problem is in the process of drawing the path.<br />
I already have some fix, that will be in the next build (end of week, or early next week), lets see if it will work.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11333</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11333</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 23 May 2022 08:57:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Mon, 23 May 2022 08:51:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I got the Closing path with pen tool issue today. If you need the example file let me know.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11332</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11332</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Mon, 23 May 2022 08:51:15 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Fri, 20 May 2022 05:28:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> I will check if the path closing in Pen tool could result in small control points still.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11286</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11286</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 20 May 2022 05:28:20 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Fri, 20 May 2022 04:30:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/jayanta-das" aria-label="Profile: Jayanta-Das">@<bdi>Jayanta-Das</bdi></a> said in <a href="/forum/post/11280">update 1.1.041</a>:</p>
<blockquote>
<p dir="auto">Still have this issue</p>
</blockquote>
<p dir="auto">Today I tried to again but the issue is not showing again.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11285</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11285</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Fri, 20 May 2022 04:30:36 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Thu, 19 May 2022 19:11:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/11268">update 1.1.041</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Thanks that you implement so quickly. It would be nice if centre pivot also hide in small shape.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11281</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11281</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Thu, 19 May 2022 19:11:15 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Thu, 19 May 2022 19:05:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in [update 1.1.041]</p>
<blockquote>
</blockquote>
<p dir="auto"><img src="/forum/assets/uploads/files/1652987099153-screenshot-2022-05-20-003307-resized.png" alt="0_1652987096641_Screenshot 2022-05-20 003307.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/11280</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11280</guid><dc:creator><![CDATA[Jayanta Das]]></dc:creator><pubDate>Thu, 19 May 2022 19:05:37 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.041 on Thu, 19 May 2022 18:15:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> thank you for the fixes! we appreciate it</p>
]]></description><link>https://www.vectorstyler.com/forum/post/11274</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/11274</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 19 May 2022 18:15:13 GMT</pubDate></item></channel></rss>
