<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.048]]></title><description><![CDATA[<h3>VectorStyler 1.1.048 release notes</h3>
<h4>Improved</h4>
<li>Erase blend mode.</li>
<li>Import or open AI files without layer content for presets and styles.</li>
<li>Allow renaming shapes inside composite shapes in the Layers panel.</li>
<li>Added a <em>Repeat Last</em> action to the Edit menu.</li>
<li>Option in Snapping panel menu to snap the whole selection box or separate boxes for each selected item.</li>
<li>Option to set a 2 line text on opposite side of a shape and control distance from path relative to leading amount.</li>
<li>Indicate in Layers panel if a group is clipped.</li>
<li>Eraser tool to keep open or unfilled paths open.</li>
<li>New <em>Remove Overlapping Segments</em> action to clean overlapping segments inside complex shapes (included text converted to curves).</li>
<li>Do not expand hairline stroke in Divide and Merge operations.</li>
<li>Node to node snapping when moving objects with the default transform tool (can be disabled in preferences).</li>
<li>Proportional scaling from the side knobs also.</li>
<li>Use the pivot selection of the Transform panel for flipping and rotating actions from the context panel.</li>
<li>Add object level <em>Clipped Effect Frame</em> option.</li>
<h4>Fixed</h4>
<li>Improved image reading from AI file format.</li>
<li>Stroke expansion inside distorted and transformed groups.</li>
<li>Show correct selection frame when duplicating objects.</li>
<li>Importing clipped gradient types from PDF files.</li>
<li>Distortion effects to correctly handle smooth corners around lines.</li>
<li>Convert text on path to curves inside transformed groups.</li>
<li>Preferences option to close lasso selection automatically.</li>
<li>Polygonal lasso selection tool to complete selection on double click.</li>
<li>Possible crash when opening files with symbol links.</li>
<li>Possible crash when exporting to SVG.</li>
<li>Export expanded vector brushes to SVG files.</li>
<li>Drawing inside transformed groups with pencil may offset the resulting shape position.</li>
<li>Correctly detach text on path options after duplication.</li>
<li>Multiple text linked to the same path.</li>
<li>Dark theme on MacOS High Sierra should use correct appearance for file panels.</li>
<li>Blend modes did not render correctly in CMYK mode.</li>
<li>Rendering stroke aligned to outside for certain open paths.</li>
<li>Changing toolbox column count should keep the top right corner fixed.</li>
<li>Missing icon in an alternate toolbox style.</li>
<li>Preview in text frame style view was not applied automatically as options were edited.</li>
<li>The <em>Transform in Text Editor</em> option should work also when creating new text frames inside existing shapes.</li>
<li>Text flow in custom shapes to better use the available space.</li>
<li>Adding to favorite fonts should also work when in font searching mode.</li>
<li>Allow folder name editing in toolbox customization, and setup default folder names.</li>
<li>Do not attach custom toolboxes next to existing toolboxes.</li>
<li>Do not initiate drag and drop with right click on the preview icons in the Layers panel.</li>
<li>Allow text variable selection while in normal object transform mode.</li>
<li>New from template should create a document view.</li>
<li>Improved memory use by the Expand Clipped Groups action.</li>
<li>Allow shortcut assignments to the shape combine actions.</li>
<li>Inserting new nodes into a path when all nodes are selected.</li>
<li>Repeated duplicating from modal view resulted in wrong undo information.</li>
<li>Undo redo stack to remain consistent after certain actions (like <em>Transformed Content</em>).</li>
<li>Font previews in the font list to have correct position and size.</li>
<li>Font list scrolling with scaled user interface resulted in broken list position.</li>
<li>Do not allow the removal of certain default folders in the Preferences view.</li>
<li>Keep the last selected export options preset name.</li>
<li>Reveal foreign files also when clicking on the file name tab with the Option (Alt) key.</li>
<li>Show current tool(s) name in status bar.</li>
<li>Do not display notdef character for alternate space characters.</li>
<li>Deselect from selection using the Shift key.</li>
<li>Keep selected export preset name.</li>
<li>In fill popover keep current color when switching to gradient fill style and use it as a gradient color.</li>
<li>Document title region did not display correctly with scaled user interface.</li>
<li>Importing multipage PDFs did not position images correctly.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2207/update-1-1-048</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:10:05 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2207.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Jul 2022 08:29:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.048 on Sun, 17 Jul 2022 11:03:28 GMT]]></title><description><![CDATA[<p dir="auto">There was a problem with snapping the point under the cursor in the Transform tool.<br />
A new build is uploaded, but the version number was not increased, so a manual install is needed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12556</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12556</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sun, 17 Jul 2022 11:03:28 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.048 on Sun, 17 Jul 2022 10:06:02 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<p dir="auto"><img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f381.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--gift" style="height:23px;width:auto;vertical-align:middle" title="🎁" alt="🎁" /> A welcome gift for @plrang <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title="🙂" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/12544</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12544</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Sun, 17 Jul 2022 10:06:02 GMT</pubDate></item></channel></rss>
