<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.050]]></title><description><![CDATA[<h3>VectorStyler 1.1.050 release notes</h3>
<p dir="auto">small fixes and improvements:</p>
<li>Pencil tool option to allow drawing with brushes (Preferences -&gt; Changing Options -&gt; Brushes with the Pencil Tool).</li>
<li>Trim and join tool did not always find intersection when the path end overlapped another part.</li>
<li>Drawing lines with the Pencil tool and Rope stabilizer enabled may result in wrong positions.</li>
<li>Do not scale or rotate when clicking and dragging an unselected object.</li>
<li>Possible crash with certain OpenType fonts when importing PDF files.</li>
<li>Crash with Eraser blend mode when transparent backdrop is disabled.</li>
<li>After using mesh editor, editing and drawing of new gradient fills are blocked.</li>
<li>Importing 16 bit images from PDFs.</li>
<li>Automatically fix display mode for imported settings files.</li>
<li>Display refresh issues observed on MacMini M1.</li>
<li>Reduce refresh lag when moving panels on Windows.</li>
<li>Refresh referenced symbols when changing.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2224/update-1-1-050</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:10:05 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2224.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Jul 2022 18:07:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.050 on Sat, 23 Jul 2022 13:20:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a><br />
Superb, thanks !</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12931</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12931</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Sat, 23 Jul 2022 13:20:03 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.050 on Sat, 23 Jul 2022 13:01:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> said in <a href="/forum/post/12921">update 1.1.050</a>:</p>
<blockquote>
<p dir="auto">the bounding box is still visible when you mouseDown on an object, the bounding box should only show when the object has been selected - ie on mouseUp</p>
</blockquote>
<p dir="auto">This will be available in 1.2</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12922</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12922</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 23 Jul 2022 13:01:30 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.050 on Sat, 23 Jul 2022 12:52:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/12828">update 1.1.050</a>:</p>
<blockquote>
<p dir="auto">Trim and join tool did not always find intersection when the path end overlapped another part.</p>
</blockquote>
<p dir="auto">Excellent, now works as it should, thanks !</p>
<blockquote>
<p dir="auto">Do not scale or rotate when clicking and dragging an unselected object.</p>
</blockquote>
<p dir="auto">This is also now working as it should - thanks ! However <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> the bounding box is still visible when you mouseDown on an object, the bounding box should only show when the object has been selected - ie on mouseUp ?</p>
<p dir="auto">Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12921</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12921</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Sat, 23 Jul 2022 12:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.050 on Fri, 22 Jul 2022 09:21:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">was also my guess, but i was a bit unshure<br />
well i am not in hurry<br />
so as always take your time</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12852</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12852</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 22 Jul 2022 09:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.050 on Fri, 22 Jul 2022 08:33:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> said in <a href="/forum/post/12849">update 1.1.050</a>:</p>
<blockquote>
<p dir="auto">use the Pen Tool more directly for Vector Brushes.</p>
</blockquote>
<p dir="auto">Will do this also later.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/12851</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12851</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 22 Jul 2022 08:33:59 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.050 on Fri, 22 Jul 2022 08:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">thanks, as always, for the fixes and improvements</p>
<p dir="auto">While I don't have a problem with it,  I don't really understand the use<br />
of the Pencil for the Vector Brushes. In principle, it only does what the Brush Tool<br />
already does anyway, or have I overlooked something ?</p>
<p dir="auto">I am for it, as I wrote in my posts, that you can use the Pen Tool more directly<br />
]]></description><link>https://www.vectorstyler.com/forum/post/12849</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/12849</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 22 Jul 2022 08:11:13 GMT</pubDate></item></channel></rss>
