<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.051]]></title><description><![CDATA[<h3>VectorStyler 1.1.051 release notes</h3>
<li>New action: Object -&gt; Shape -&gt; Separate at Intersections to self intersect and separate paths.</li>
<li>Snapping should also work when dragging from a path node.</li>
<li>Eraser tool to cut from end of open paths.</li>
<li>Duplicating inside transformed groups should position objects correctly.</li>
<li>Area zoom marque was not displayed correctly when activated from the transform tool.</li>
<li>Area zoom should also work for zoom out.</li>
<li>Blending cloned objects did not work.</li>
<li>Recorded actions should activate by the first action.</li>
<li>Confirming a number in the snapping space editor should also add it.</li>
<li>Deleting a node did not keep the path selected.</li>
<li>Click selection of complex shapes did not handle negative space correctly.</li>
<li>Keep objects selected on the canvas when changing stacking order in the Layers panel.</li>
<li>Allow adding separators into contextual menus.</li>
<li>Outline highlight did not show correctly on Windows at large zoom.</li>
<li>Activating shape editor without a selection should highlight nodes when hovering over editable paths.</li>
<li>General stability improvements.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2249/update-1-1-051</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:10:02 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2249.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jul 2022 18:46:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.051 on Wed, 27 Jul 2022 10:29:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/devil-dinosaur" aria-label="Profile: Devil-Dinosaur">@<bdi>Devil-Dinosaur</bdi></a></p>
<p dir="auto">My Post about Clones loosing link<br />
on Fill is her<br />
<a href="https://www.vectorstyler.com/forum/topic/2256/clones-doesnt-work-as-clones-if-i-change-fill-color-of-a-clone">Link</a></p>
<p dir="auto">But i dont know maybe you create a extra one<br />
as your Problem is different</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13135</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13135</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 27 Jul 2022 10:29:38 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Wed, 27 Jul 2022 10:23:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> said in <a href="/forum/post/13132">update 1.1.051</a>:</p>
<blockquote>
<p dir="auto">i just would say that i like that Blend will now<br />
working with Clones.</p>
<p dir="auto">Note:<br />
There is a yet Bug when changing a Fill in Clones<br />
it will not work as a Clone anymore.<br />
But that Bug is already mentioned.</p>
</blockquote>
<p dir="auto">I had the same problem after moving a clone to another layer than the one it has been created on, it lost its "connection".</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13134</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13134</guid><dc:creator><![CDATA[Devil Dinosaur]]></dc:creator><pubDate>Wed, 27 Jul 2022 10:23:22 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Wed, 27 Jul 2022 09:17:50 GMT]]></title><description><![CDATA[<p dir="auto">i just would say that i like that Blend will now<br />
<p dir="auto"><a href="https://recordit.co/OVeAUk77TI" rel="nofollow ugc">Here a Video to show how it works:</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1658913294680-clones-with-blend.png" alt="0_1658913217596_Clones-with Blend.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13132</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13132</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Wed, 27 Jul 2022 09:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 17:04:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> I keep this issue open.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13077</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13077</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 26 Jul 2022 17:04:42 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 16:57:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> Confirmed here.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13074</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13074</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 26 Jul 2022 16:57:31 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 16:46:03 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://i.imgur.com/tkRiZpx.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13072</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13072</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 26 Jul 2022 16:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 16:39:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I don't see it working in any scenario:</p>
<p dir="auto"><img src="https://i.imgur.com/5cZgHFt.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13071</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13071</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 26 Jul 2022 16:39:18 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 14:37:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> A recording would help, it is important to know what kind of order changes are made in the Layers panel to be able to replicate this.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13058</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13058</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 26 Jul 2022 14:37:58 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Tue, 26 Jul 2022 14:22:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13023">update 1.1.051</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">I don't see this working in .051 (Only have Windows here)</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13056</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13056</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 26 Jul 2022 14:22:11 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.051 on Mon, 25 Jul 2022 20:33:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13023">update 1.1.051</a>:</p>
<blockquote>
<p dir="auto">Snapping should also work when dragging from a path node.</p>
</blockquote>
<p dir="auto">Works well, thanks !</p>
<blockquote>
<p dir="auto">Eraser tool to cut from end of open paths.</p>
</blockquote>
<p dir="auto">Fixed - thanks !</p>
<blockquote>
<p dir="auto">Area zoom marque was not displayed correctly when activated from the transform tool.</p>
</blockquote>
<blockquote>
<p dir="auto">Area zoom should also work for zoom out.</p>
</blockquote>
<blockquote>
<p dir="auto">Allow adding separators into contextual menus.</p>
</blockquote>
<blockquote>
<p dir="auto">Activating shape editor without a selection should highlight nodes when hovering over editable paths.</p>
</blockquote>
<p dir="auto">Can't believe how quickly stuff is fixed in VS, that's a lot of work and commitment and <strong>really</strong> appreciated !!</p>
<p dir="auto">Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13030</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13030</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Mon, 25 Jul 2022 20:33:34 GMT</pubDate></item></channel></rss>
