<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 201]]></title><description><![CDATA[<h3>VectorStyler beta 201 release notes</h3>
<li>Improved: separate release of Apple M1 optimized version.</li>
<li>Improved: use extended frame of selected objects for artboard size when copying or exporting.</li>
<li>Fixed: default brush can also be a solid stroke.</li>
<li>Fixed: indicate selection of newly drawn shapes in the pen and brush tools.</li>
<li>Fixed: start a new path in pencil tool with command+clicking away.</li>
<li>Fixed: artboard sizes may change when copying objects.</li>
<li>Fixed: file format order in profile popup.</li>
<li>Fixed: open recent to notify if file cannot be located.</li>
<li>Fixed: opacity slider in inner shadow effect was not working.</li>
<li>Fixed: resizing rectangles from the side at small zoom levels caused resize in the other direction also.</li>
<li>Fixed: color panel to show color from gradient of selected object.</li>
<li>Fixed: moving multiple selected nodes in the path editor should snap at each node to snapping locations.</li>
<li>Fixed: multiple ungroup commands may result in need for a Command+R refresh.</li>
<li>Fixed: swap the top fill and stroke colors with shift+x.</li>
<li>Fixed: showing images in outline mode broke the rendering of objects above.</li>
<li>Fixed: place the brush options at the context panel closer to the left side (for small screens).</li>
<li>Fixed: use <em>Shift</em> in guideline moving to constrain to round values (depending on document units).</li>
<li>Fixed: deleting the starting node in a closed path caused corner shifting.</li>
<li>Fixed: could not immediately select and mode nodes when swapping to the node tool with command+.</li>
<li>Fixed on Windows: image handling bug with NVidia compute mode.</li>
<li>Fixed on Windows: Shift+ modifier restricted to wrong scaling amounts.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/227/build-201</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:20 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/227.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jan 2021 06:45:19 GMT</pubDate><ttl>60</ttl></channel></rss>
