<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.053]]></title><description><![CDATA[<p dir="auto">VectorStyler 1.1.053 release notes</p>
<li>Added color separation options to Region and Object Content intensity modes in Repeaters.</li>
<li>Importing text on path from AI format.</li>
<li>Drag and drop in Appearance panel for selected text.</li>
<li>Copy and paste font names in the missing and replace font view.</li>
<li>Possible crash with duplicated patterns and linked pattern styles.</li>
<li>Pattern fill style was not selected when searched by attrribute.</li>
<li>Docked alignment panel sizing problems.</li>
<li>Improved Separate at Intersections command.</li>
<li>Switching to Pen tool should not deactivate Draw Inside mode.</li>
<li>New from Clipboard to add root layer if needed.</li>
<li>Gradient and pattern editing undo was not handled correctly.</li>
<li>Importing curves from SVG should not add smooth node before or after lines.</li>
<li>Image effect styles were not selected correctly.</li>
<li>Accessing repeater content in Layers panel when used on groups or images.</li>
<li>Color map effect view layout was broken.</li>
<li>Node deletion should update smooth nodes correctly.</li>
<li>Box blur rendering was broken in rotated views.</li>
<li>Automatically select gradient node when creating a new gradient or activating the gradient editor.</li>
<li>Select opposite gradient color on right click (or Option click).</li>
<li>Allow text on path dragging in the transform tool.</li>
<li>Option to search by color when automatically adding new spot colors to the palette.</li>
<li>Layers panel highlight did not update correctly when previewing shape combine effects.</li>
<li>Added a document view title leaf tool tip.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2308/update-1-1-053</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:10:08 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2308.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Aug 2022 17:33:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 07:16:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> Gradient color selection issue from palette panel can be replicated. Will be fixed ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13584</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13584</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Aug 2022 07:16:27 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 07:06:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/encart" aria-label="Profile: encart">@<bdi>encart</bdi></a> said in <a href="/forum/post/13580">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">There is a selection  regression in the latest build</p>
</blockquote>
<p dir="auto">Yes, this replicates here also. Will be fixed ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13582</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13582</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Aug 2022 07:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 06:30:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> There is a selection  regression in the latest build.  Previously I was able to hold CTRL down and select a node/part of the object and  the selection would remain when I let go of CTRL.<br />
<a href="https://recordit.co/VqhQDKN0Kk" rel="nofollow ugc">https://recordit.co/VqhQDKN0Kk</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13580</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13580</guid><dc:creator><![CDATA[encart]]></dc:creator><pubDate>Wed, 10 Aug 2022 06:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 05:22:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13574">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> said in <a href="/forum/post/13563">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">It is not possible to right click the the same color you just left clicked, no effect.</p>
</blockquote>
<p dir="auto">Is this in the color panel or palette? I cannot replicate either cases.</p>
</blockquote>
<p dir="auto">Easy:</p>
<p dir="auto"><img src="https://i.imgur.com/0ldUYmJ.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13579</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13579</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Wed, 10 Aug 2022 05:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 04:57:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> said in <a href="/forum/post/13552">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">If this is where you are referring, I'm not sure how to copy and paste names here.</p>
</blockquote>
<p dir="auto">Yes, but not with right click. Only Command+C/V</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13578</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13578</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Aug 2022 04:57:46 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 04:19:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> said in <a href="/forum/post/13563">update 1.1.053</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/13574</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13574</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Aug 2022 04:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Wed, 10 Aug 2022 04:17:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/ingolf" aria-label="Profile: Ingolf">@<bdi>Ingolf</bdi></a> said in <a href="/forum/post/13559">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">regression - you have to click once with the mouse over an object to activate the gradient tool and see the gradient tool symbol</p>
</blockquote>
<p dir="auto">Yes, this can be replicated. Added it to the backlog.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13573</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13573</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 Aug 2022 04:17:05 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 21:24:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> It is not possible to right click the the same color you just left clicked, no effect.</p>
<p dir="auto">Useful if your next step is to create a third gradient stop in the middle with for example yellow with a blue gradient stop left and right.</p>
<p dir="auto">Not a big issue of course but it is a bit wierd that it does nothing in this scenario.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13563</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13563</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 09 Aug 2022 21:24:44 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:44:23 GMT]]></title><description><![CDATA[<p dir="auto">0.52 where it works as expected</p>
<p dir="auto"><img src="https://i.imgur.com/GFvtvma.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13560</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13560</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:57:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> A regression - you have to click once with the mouse over an object to activate the gradient tool and see the gradient tool symbol:</p>
<p dir="auto">0.53</p>
<p dir="auto"><img src="https://i.imgur.com/A5RrtQg.gif" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13559</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13559</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:57:46 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:44:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> <a href="https://www.vectorstyler.com/forum/topic/2306/creating-a-new-gradient-with-option-drag-could-do-something-useful">My suggestion</a> didn't — the app was already compiled.<br />
And we're still debating what Option-drag should do anyway. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13558</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13558</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:26:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> great that you like it<br />
indeed much more smooth then before</p>
<p dir="auto">... You must have had perfect timing to discuss it ....<br />
sometimes things lie in the air <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
but i also guess that the task wasnt too hard</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13556</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13556</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:26:37 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:08:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> said in <a href="/forum/post/13551">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">Is such a joy to work with Gradients now.</p>
</blockquote>
<p dir="auto">Great suggestions for improvement to the gradient tool <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a><br />
I'm loving the new ways to change the colors of the gradient on the fly like that.<br />
You must have had perfect timing to discuss it when you did and for <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> to slip it in on this latest build! haha</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13555</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13555</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:06:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/13553">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I can copy the name of the font with Cmd-C if I simply select the row.</p>
</blockquote>
<p dir="auto">ok that worked - thanks. Both the ability to select a replacement font and the new ability to copy a font name are awesome - but neither is obvious from the way the menu is currently set up.<br />
Would it help to have more of a visual indication? Such as a downward triangle on the replacement font name and maybe a highlight appear on the missing font name when copied? Just thoughts....</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13554</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13554</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:06:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 20:03:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I can copy the name of the font with Cmd-C if I simply select the row.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13553</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13553</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 09 Aug 2022 20:03:11 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 19:52:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13545">update 1.1.053</a>:</p>
<blockquote>
<p dir="auto">Copy and paste font names in the missing and replace font view.</p>
</blockquote>
<p dir="auto">If this is where you are referring, I'm not sure how to copy and paste names here. If I right-click or left click, nothing happens with the name side.<br />
Clicking on the "replace" side gives me the font menu as desired<br />
<img src="/forum/assets/uploads/files/1660074736039-9e10764f-4d67-4e79-9f45-dc5fee9a11cb-bld-2022-08-09-at-15.50.22.png" alt="0_1660074734473_9e10764f-4d67-4e79-9f45-dc5fee9a11cb-BLD 2022-08-09 at 15.50.22.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13552</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13552</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 09 Aug 2022 19:52:19 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.053 on Tue, 09 Aug 2022 19:51:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>, that was so lighting fast <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f62e.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--open_mouth" style="height:23px;width:auto;vertical-align:middle" title=":open_mouth:" alt="😮" /></p>
<p dir="auto">For all who doesnt know.<br />
Two things are new on Gradients now.</p>
<p dir="auto">First<br />
If you create a Gradient the last Fill Color of your Object<br />
will already be selected.</p>
<p dir="auto">Second<br />
the second is related to the first one:<br />
If you have choossen you first Gradient Color<br />
you just can right click another color,<br />
these will fill the opposide Fill Node in a Gradient</p>
<p dir="auto">Btw the old way of doing Gradients is still working.</p>
<p dir="auto"><a href="https://recordit.co/TtPb05989K" rel="nofollow ugc">see Video here</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1660074535529-opposite-color.png" alt="0_1660074447911_Opposite Color.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/13551</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13551</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Tue, 09 Aug 2022 19:51:14 GMT</pubDate></item></channel></rss>
