<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Am wondering if there&#x27;s a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad).]]></title><description><![CDATA[<p dir="auto">Am wondering for convinience's sake if there's a way to assign two different shortcuts to a single command? e.g. For Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad) at any moment...</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2317/am-wondering-if-there-s-a-way-to-assign-two-different-shortcuts-to-a-single-command-e-g-zoom-to-artboard-i-could-choose-to-use-control-0-or-control-0-from-the-numeric-pad</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 11:37:27 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2317.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Aug 2022 10:30:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Am wondering if there&#x27;s a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad). on Thu, 06 Apr 2023 13:28:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a> Yes, it is in the backlog and not yet implemented.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18154</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18154</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 06 Apr 2023 13:28:22 GMT</pubDate></item><item><title><![CDATA[Reply to Am wondering if there&#x27;s a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad). on Thu, 06 Apr 2023 12:53:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I bumped into this one today, trying to figure out why ctrl-num-0 was not implemented / adding manual shortcut did not work. Is this still on the backlog?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18153</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18153</guid><dc:creator><![CDATA[syllie]]></dc:creator><pubDate>Thu, 06 Apr 2023 12:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to Am wondering if there&#x27;s a way to assign two different shortcuts to a single command? e.g. Zoom to Artboard I could choose to use Control+0 or Control+0 (from the numeric pad). on Sat, 13 Aug 2022 18:58:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> It seems that an action can be added only once into the shortcut list.<br />
This is an unnecessary limitation. Will be fixed ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13643</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13643</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 13 Aug 2022 18:58:49 GMT</pubDate></item></channel></rss>
