<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.054]]></title><description><![CDATA[<h3>VectorStyler 1.1.054 release notes</h3>
<li>Configurable zoom change amounts.</li>
<li>Keep selection when temporarily switching to transform tool from node selection.</li>
<li>Fixed pattern mask boundary in image filters.</li>
<li>Use right click in palette panel to select second gradient color.</li>
<li>Show gradient editor cursor when hovering over objects.</li>
<li>Double clicking on gradient handles should not isolate.</li>
<li>Dragging curve segments with smooth or symmetric nodes did not update correctly.</li>
<li>Navigator popup did not always display content.</li>
<li>Slow rendering of bitmap images.</li>
<li>Blend shape effects when shape blending is enabled.</li>
<li>Path brush did not merge correctly with intersecting shapes.</li>
<li>New path brush option to create separate shapes.</li>
<li>Possible undo blocking when using clones or gradient editor.</li>
<li>Artboard tool selection did not work after exiting from isolation mode.</li>
<li>Pencil tool rope stabilizer mode was not correctly updated.</li>
<li>Guideline editor did not display the location of a guideline correctly when top-down coordinates were enabled.</li>
<li>When adding new stroke to an object with the shortcut keys, use the fill color as the stroke color.</li>
<li>Allow empty fill for selected characters in text.</li>
<li>User interface field tab traversal in backward direction did not follow the correct order.</li>
<li>Do not add registration and null color to the palette if already exists.</li>
<li>Default palette options for global colors.</li>
<li>Destructive color filters applied to images did not redraw correctly.</li>
<li>Drawing new gradient on a rotated object displayed wrong handle positions.</li>
<li><em>Exclude Back</em> and <em>Exclude Last</em> shape operations did not follow object order correctly.</li>
<li>Select color group source automatically when creating new color groups.</li>
<li>Editing color groups should correctly fetch the first color.</li>
<li>Allow color group removal using the delete button of the color palette panel.</li>
<li>Drag and drop of color group resulted in broken palette.</li>
<li>Reorganize the color palette panel menu.</li>
<li>Allow new fill and stroke to be added in the Appearance panel when using the shape editor tool.</li>
<li>Absolute stroke offset did not work with dashed stroke.</li>
<li>Improved offset stroke rendering precision.</li>
<li>Update snapping panel preset name when settings are changed.</li>
<li>New action to convert the content of a text frame to curves.</li>
<li>Allow changing of the text on path shape source for existing text on path objects.</li>
<li>Move and transform commands with modal views to work with node selection also.</li>
<li>Dragging symbols from the Symbols panel should also work if objects are selected on the canvas.</li>
<li>Collider tool to work with guidelines (if guideline snapping is enabled).</li>
<li>Pressing a modifier key after confirming modal views did not always work.</li>
<li>Allow multiple copies of an action in the shortcut editor.</li>
<li>Persistent proportional option when editing the Transform shape effect.</li>
<li>Repeater changes should not result in unnecessary undo steps.</li>
<li>Duplicating a canvas did not refresh correctly when changing canvases.</li>
<li>Fixed touch pad object dragging issues appearing on Monterey.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/2341/update-1-1-054</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:10:03 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2341.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Aug 2022 03:44:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.054 on Mon, 22 Aug 2022 14:09:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> said in <a href="/forum/post/13809">update 1.1.054</a>:</p>
<blockquote>
<p dir="auto">looks like an issue in outline preview only</p>
</blockquote>
<p dir="auto">This could be the reason.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13810</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13810</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 22 Aug 2022 14:09:16 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.054 on Mon, 22 Aug 2022 13:57:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13804">update 1.1.054</a>:</p>
<blockquote>
<p dir="auto">Preferences -&gt; Document Display -&gt; Clicking and Repeated zoom factor. Used when zooming in or out with the zoom tool by clicking.</p>
</blockquote>
<p dir="auto">Got it !  Excellent, really makes the area zoom and mouseclick work well together now - I'm at 35% and that seems perfect for me.</p>
<blockquote>
<p dir="auto">yes, it should be the same issue. Is the slowness observed with those PDF examples you sent me?</p>
</blockquote>
<p dir="auto">Yes, still the same slowness - I was testing moving a node using the move panel and if you hide and show the PDF, and use the preview button on the panel to show the effect, you see a substantial delay when the node moves. Simply dragging an object shows a delay also.<br />
<strong>Edit</strong>: I use <em>outline preview</em> most of the time and was in that mode when testing - I've since jumped into <em>vector preview</em> and it looks fine there - so, looks like an issue in <em>outline preview</em> only - also looks in <em>pixel preview</em> too.</p>
<p dir="auto">Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13809</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13809</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Mon, 22 Aug 2022 13:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.054 on Mon, 22 Aug 2022 12:49:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> said in <a href="/forum/post/13801">update 1.1.054</a>:</p>
<blockquote>
<p dir="auto">Can't find this option anywhere, unless you don't mean mouse click zoom level steps using the <em>area zoom</em> tool</p>
</blockquote>
<blockquote>
<p dir="auto">Still <em>very</em> slow here and causing real sluggishness in the GUI - unless this is different from my issue ?</p>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/13804</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13804</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Mon, 22 Aug 2022 12:49:38 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.054 on Mon, 22 Aug 2022 11:54:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/13787">update 1.1.054</a>:</p>
<blockquote>
<p dir="auto">Configurable zoom change amounts</p>
</blockquote>
<p dir="auto">Can't find this option anywhere, unless you don't mean mouse click zoom level steps using the <em>area zoom</em> tool  ?</p>
<blockquote>
<p dir="auto">Slow rendering of bitmap images</p>
</blockquote>
<blockquote>
<p dir="auto">Guideline editor did not display the location of a guideline correctly when top-down coordinates were enabled</p>
</blockquote>
<p dir="auto">Confirmed working.</p>
<blockquote>
<p dir="auto">Move and transform commands with modal views to work with node selection also</p>
</blockquote>
<p dir="auto">Confirmed working - thanks !</p>
<blockquote>
<p dir="auto">Collider tool to work with guidelines (if guideline snapping is enabled)</p>
</blockquote>
<p dir="auto">Confirmed working - excellent !!</p>
<p dir="auto">Thanks</p>
]]></description><link>https://www.vectorstyler.com/forum/post/13801</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/13801</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Mon, 22 Aug 2022 11:54:18 GMT</pubDate></item></channel></rss>
