<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 205]]></title><description><![CDATA[<h3>VectorStyler beta 205 release notes</h3>
<li>Fixed: linear gradient interactive editor color selection and indication was flipped.</li>
<li>Fixed: general stability improvements.</li>
<li>Fixed: automatic revert should also work when a file is changed and then saved.</li>
<li>Fixed: reorganize context panel for brush and pen tools.</li>
<li>Fixed: importing some PDF files ignored font transformations.</li>
<li>Fixed: ignore fixed glyph positioning in imported PDF when replacing fonts.</li>
<li>Fixed: PDF export view image label alignment.</li>
<li>Fixed: default tab in character and paragraph style views.</li>
<li>Fixed: opacity numeric field in appearance panel did not select value.</li>
<li>Fixed: closing one of the docked panels in the same stack should not close all.</li>
<li>Fixed: corner shape popover layout.</li>
<li>Fixed: UI style changes and improvements.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/236/build-205</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/236.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jan 2021 12:13:24 GMT</pubDate><ttl>60</ttl></channel></rss>
