<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 206]]></title><description><![CDATA[<h3>VectorStyler beta 206 release notes</h3>
<li>Improved: add image effect scaling option to appearance panel.</li>
<li>Improved: option to create smooth nodes in the pen tool.</li>
<li>Improved: add slider to the distance field in Offset Path.</li>
<li>Improved: compatibility with legacy macos.</li>
<li>Improved: non-uniform sliders in percentage fields.</li>
<li>Fixed: problems in union of shapes with overlapping sides.</li>
<li>Fixed: brush did not show with some shapes.</li>
<li>Fixed: text cursor and highlight in wrong position for flipped fonts (resulting from pdf import).</li>
<li>Fixed: node deletion did not update some corners correctly.</li>
<li>Fixed: selecting with click did not work on some horizontal strokes.</li>
<li>Fixed: color filtering of duplicate mesh objects should not change the original.</li>
<li>Fixed: add color filters to images when applying a destructive color filter.</li>
<li>Fixed: scaling rectangle and ellipse shapes should also scale transformed stroke.</li>
<li>Fixed: possible crash in hyphenation dictionary access.</li>
<li>Fixed: artboard tool may jump to an empty canvas.</li>
<li>Fixed: click and drag selection in node tool to ignore whole object selection.</li>
<li>Fixed: exclude created a smooth node at a cusp node.</li>
<li>Fixed: scaling of a rectangle with a smooth corner shapes resulted in wrong node types.</li>
<li>Fixed: hidden guidelines should not be selectable.</li>
<li>Fixed: guideline locking did not work.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/246/build-206</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:18 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/246.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Jan 2021 11:48:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 206 on Sat, 23 Jan 2021 15:50:57 GMT]]></title><description><![CDATA[<p dir="auto">Great improvements and fixes - thank you for adding our suggestions as you saw fit.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/934</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/934</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Sat, 23 Jan 2021 15:50:57 GMT</pubDate></item></channel></rss>
