<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 207]]></title><description><![CDATA[<h3>VectorStyler beta 207 release notes</h3>
<li>Improved: pen tool to snap to starting node, to indicate closing.</li>
<li>Improved: checkerboard backdrop in layers (and appearance) panel previews.</li>
<li>Improved: changed some shortcuts for better MacOS compatibility.</li>
<li>Improved: refresh performance with multiple image effects.</li>
<li>Fixed: did not use last solid brush width.</li>
<li>Fixed: possible crash in text editor with some input methods.</li>
<li>Fixed: crash while editing guidelines.</li>
<li>Fixed: do not allow diagonal movement for shift constrain.</li>
<li>Fixed: removing first node in an open path did not reset corners correctly.</li>
<li>Fixed: do not allow guideline adding from ruler, if guidelines are hidden.</li>
<li>Fixed: excluding from multiple individually scaled objects inside a group created wrong shapes.</li>
<li>Fixed: nonuniform slider in blend and contour panels and views.</li>
<li>Fixed: better handle certain font metrics for text shapes (point text).</li>
<li>Fixed: faster union operation for large number of shapes.</li>
<li>Fixed: did not show some self intersecting outline stripes.</li>
<li>Fixed: color filter previewing did not always work.</li>
<li>Fixed: freeze when accessing layer options.</li>
<li>Fixed: possible crash with certain OpenType fonts.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/251/build-207</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:44:34 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/251.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jan 2021 08:42:06 GMT</pubDate><ttl>60</ttl></channel></rss>
