<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transform Bugs ?]]></title><description><![CDATA[<p dir="auto">I'm having some strange bugs tonight, a couple of rectangles, select the top centre node in the transform panel, set the size to be 100x100 from 100x200 - the rectangle resizes, but around it's centre. Chose the LH rectangle and do the same - OK ??????<br />
"Transformed Frame" is selected in the transform pop menu.<br />
Earlier, I had a similar problem, select the top centre node in the transform panel, resize the rectangle and the node position changed on the panel ??? (enter a size in the required editfield and hit return).<br />
I did have similar issues some months ago with X &amp; Y sizing being swapped after rotation, but "Transformed Frame" was the answer (thanks <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> )<br />
I can't get to the bottom of this - repeatability seems to vary <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">Video here ...</p>
<p dir="auto"><a href="https://recordit.co/pkiC9JEkWm" rel="nofollow ugc">https://recordit.co/pkiC9JEkWm</a></p>
<p dir="auto">Update: Just did some more digging and it seems to happen after you have rotated the rectangle 90deg. Even more digging, rotate 90deg again and it goes haywire <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2673/transform-bugs</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 22:16:32 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2673.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Nov 2022 20:15:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transform Bugs ? on Mon, 01 May 2023 11:52:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">Yes, definitely fixed and works as expected now (for me at least <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> )</p>
<p dir="auto">Something else that is fixed it seems is the object refresh after changing it's size via the transform panel - prior to 080, the new object size indicated in the panel correctly, but was changed on screen. I'll keep my eye on that just in case I might be wrong <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18415</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18415</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Mon, 01 May 2023 11:52:02 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Tue, 03 Jan 2023 06:45:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> This issue should be fixed in build 1.1.072</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17082</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17082</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 03 Jan 2023 06:45:22 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Thu, 24 Nov 2022 11:51:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> I think the main  problem is than when the Transformed Frame is enabled, the pivot selection knob should not rotated anymore.</p>
<p dir="auto">But of course, the transform box selection on the canvas will not indicate correctly this case.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16128</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16128</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 24 Nov 2022 11:51:29 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Thu, 24 Nov 2022 11:46:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/16107">Transform Bugs ?</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> Replicated!. I will try to figure out what what would be a good solution here.<br />
The problem is that all these transforms, and the pivot selection are non-destructive.</p>
</blockquote>
<p dir="auto">Glad that it wasn't just me <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">I can understand that this will certainly be an issue if all the transformations are non-destructive - I imagine a large database of transforms for each and every object contained in every file <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":-(" alt="😞" /></p>
<p dir="auto">However, regarding the mimic panel (I'm calling it the mimic panel - the one with all the nodes on it - you might have called it the <em>pivot selection</em> ? <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> ) - if you select the target object then select the required bounding box pivot point to operate on, it should operate on that node <em>as seen visually and currently</em> - not on whatever transforms have happened prior to this - the user will probably have no idea what the original orientation is/was. That's my thinking and expected operation at least (and what happens in AI too LOL).</p>
<p dir="auto">Edit: There is one thing that I have assumed to be true, and that is that the bounding box of <strong>any</strong> object will remain vertical/horizontal after it has been "transformed" and will only show as anything other than that during the actual transformation - I don't expect to see a bounding box at some odd angle afterward ? This might be an issue <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/16127</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16127</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Thu, 24 Nov 2022 11:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Thu, 24 Nov 2022 05:23:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> Replicated!. I will try to figure out what what would be a good solution here.<br />
]]></description><link>https://www.vectorstyler.com/forum/post/16107</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16107</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 24 Nov 2022 05:23:01 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Wed, 23 Nov 2022 21:31:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> I don't know if there is a Prefs setting that disables the default behavior — the developer knows that.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16105</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16105</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Wed, 23 Nov 2022 21:31:06 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Wed, 23 Nov 2022 21:29:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a></p>
<p dir="auto">No, that's not a solution (for me at least) - why would you ever want that anyway ?? Surely the default needs to be the inverse of that - NOT to have to 'reset transform' on every single object that you might want to transform (like EVERY object in my book <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> )???? That's assuming that 'reset transform' isn't a global switch ' ?? In which case, if it WAS, then a preference needs to be set for that IMHO <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /><br />
Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16104</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16104</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Wed, 23 Nov 2022 21:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Wed, 23 Nov 2022 21:19:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> After rotating the object, you can use 'Reset Transform' from the Object menu &gt; Transform if you need that.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16103</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16103</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Wed, 23 Nov 2022 21:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Wed, 23 Nov 2022 21:07:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a></p>
<p dir="auto">You have to be joking, surely ???</p>
<p dir="auto">That just seems absolute nuts to me LOL - the object reference is wherever <strong>you</strong> select on the "mimic" display on the transform panel surely (with reference to it's bounding box - that is the bounding box as <strong>currently viewed</strong> - ie, top is top etc - NOT top is left if it had been rotated 90deg !!!!!) - otherwise, what is the point of the mimic display?</p>
<p dir="auto">You don't need a video to see any of these effects, just rotate a rectangle 90deg, change the reference node and resize - it should resize against the reference node and it should NOT move the reference point on the mimic panel afterwards either, surely ???</p>
<p dir="auto">This is as bad as putting pushbutton switches on the steering wheel of the car LOL - they move when you move the wheel - wonderful idea - not  (just like my VW <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> ) /rant</p>
<p dir="auto">Please tell me this is NOT the way it was intended to be or I'll go back to AI (well maybe that might be one step too far LOL <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /> )</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16102</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16102</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Wed, 23 Nov 2022 21:07:15 GMT</pubDate></item><item><title><![CDATA[Reply to Transform Bugs ? on Wed, 23 Nov 2022 20:48:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> The  reference point of the transform widget is linked to the bounding box of the object.</p>
<p dir="auto">If you rotate it -90°, the app "moves" the reference point of the transform widget from top-center to center-right and applies any resizing from that point.</p>
<p dir="auto">(Actually it's not moved, it rotates with the bounding box).</p>
<p dir="auto">If you rotate it back to 0°, the reference point will be back to top-center and scale from that point.</p>
<p dir="auto">If you rotate it 180°, it will "move" to the bottom center and scale/transform accordingly.</p>
<p dir="auto">If you did find a situation where this rule breaks, record a short video with the glitch.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/16101</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/16101</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Wed, 23 Nov 2022 20:48:47 GMT</pubDate></item></channel></rss>
