<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[build 209]]></title><description><![CDATA[<h3>VectorStyler beta 209 release notes</h3>
<li>Improved: working with multiple image effects, refresh performance.</li>
<li>Improved: simplified gradient tool, with smaller handle sizes</li>
<li>Improved: added option to enable color calibration in UI also (User Interface section of Preferences).</li>
<li>Improved: changed font sharpness mode on Windows.</li>
<li>Improved: added an <em>Extra Dark</em> and <em>Extra Light</em> theme for better contrast.</li>
<li>Improved: automatic save mode will not ask to save modified files.</li>
<li>Improved: added option to Pen tool to block path editing.</li>
<li>Fixed: selecting colors from the color palette bar used wrong colors.</li>
<li>Fixed: duplicate panels opened from customized context panel.</li>
<li>Fixed: union of multiple shapes may result in the wrong shape.</li>
<li>Fixed: stretched menu font on Windows.</li>
<li>Fixed: associating files with app on Windows.</li>
<li>Fixed: could not select multiple corners with the corner tool.</li>
<li>Fixed: when exporting artboard, first artboard size reverted to default size.</li>
<li>Fixed: flipping from eraser to pen side on Wacom tablet to return to last tool used.</li>
<li>Fixed: add new gradient color in interactive editing with a single click.</li>
<li>Fixed: possible crash in working with gradients.</li>
<li>Fixed: global color settings were not persistent.</li>
<li>Fixed: cannot resize lines from transform panel.</li>
<li>Fixed: persistent proportional mode in transform panel.</li>
<li>Fixed: breaking at multiple selected nodes did not work.</li>
<li>Fixed: add smooth nodes around round corners.</li>
<li>Fixed: moving or duplicating artboards did not move the guidelines of the artboard.</li>
<li>Fixed: creating a grid of guidelines did not work on some artboards.</li>
<li>Fixed: changing artboard size with the artboard tool reverted to a default size.</li>
<li>Fixed: skewing multiple (previously skewed) objects created the wrong transform.</li>
<li>Fixed: Option+ drag a control point to change node to cusp.</li>
<li>Fixed: Command+ drag a control point to change node to smooth.</li>
<li>Fixed: setting a node to smooth or symmetric from the Path panel or the context panel should move the opposing control point.</li>
<li>Fixed: rounded corner extreme cases were not handled correctly.</li>
<li>Fixed: previewing and canceling color filters created wrong object attributes.</li>
<li>Fixed: several crashes specific to Windows.</li>
<li>Fixed: refreshing the screen with OpenGL when using the dynamic erase mode of the pen tool.</li>
<li>Fixed: possible crash when importing ASE color palette files.</li>
<li>Fixed: moving lines next to smooth nodes should adjust smooth controls also.</li>
<li>Fixed: improve cursor images on Windows.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/271/build-209</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:10 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/271.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Feb 2021 20:10:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to build 209 on Fri, 12 Feb 2021 04:45:42 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin said in <a href="/forum/post/1021">build 209</a>:</p>
<blockquote>
<p dir="auto">Improved: added option to enable color calibration in UI also (User Interface section of Preferences).</p>
</blockquote>
<p dir="auto">The setting is there but it doesn't make a difference. I still see vivid wrong colours on my wide gamut screen like in other programs that doesn't utilize my monitor profile generated by myself with my spectrometer etc. etc.</p>
<p dir="auto">Windows 10 Enterprise N, 20H2</p>
]]></description><link>https://www.vectorstyler.com/forum/post/1058</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/1058</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Fri, 12 Feb 2021 04:45:42 GMT</pubDate></item></channel></rss>
