<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error in reading Illustrator layer hierarchy]]></title><description><![CDATA[<p dir="auto">I noticed an error in interpreting Illustrator-created native layer structure.</p>
<p dir="auto">In the attached file, when the option to read AI data from a PDF is checked, the native AI layer structure the "Reddish" sub layer under Ellipses is duplicated with its content with the name "Reddish_2_", but is otherwise correctly read in -- which is great since no other sofware I know can (or even try to) do that (they all basically flatten the layer hierarchy and do not maintain group structures under layers).</p>
<p dir="auto"><a href="/forum/assets/uploads/files/1673431883641-layers_ai.pdf">0_1673431882721_layers_ai.pdf</a></p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2843/error-in-reading-illustrator-layer-hierarchy</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 03:37:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2843.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2023 10:28:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error in reading Illustrator layer hierarchy on Wed, 11 Jan 2023 11:19:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/arde" aria-label="Profile: Arde">@<bdi>Arde</bdi></a> In Preferences enable Document Files -&gt; Import AI data from PDF.</p>
<p dir="auto">this option is disabled by default for PDF files so that the actual PDF content is imported.</p>
<p dir="auto">and by default, AI content is only imported from files with AI extensions.</p>
<p dir="auto">same happens with EPS.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17203</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17203</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 11 Jan 2023 11:19:39 GMT</pubDate></item></channel></rss>
