<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gradient Mask Effect fails to transform]]></title><description><![CDATA[<p dir="auto">Thank you for the latest update (VS 1.1.073) @VectorStyler.<br />
I however have encountered a worrisome behaviour in regards to the Gradient Mask. The Gradient Mask Effect's position remains anchored when transforming artwork using rotate, skew or reflect. The artwork will transform but the effect will not budge.</p>
<p dir="auto">Is this the new dispensation or it is a bug?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/2844/gradient-mask-effect-fails-to-transform</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 16:45:37 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/2844.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2023 11:02:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gradient Mask Effect fails to transform on Wed, 11 Jan 2023 12:15:36 GMT]]></title><description><![CDATA[<p dir="auto">Thank you @Vectorstyler.<br />
It worked, but I would prefer that Transform Mask Content be enabled by default. I think it would be more efficient that way. I feel it's an awful bore to have to revert to the Transparency Panel Menu each time I need to make a transformation. All the same I also would like to tap into other users input. I very much would want to hear their thoughts on this one.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17207</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17207</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Wed, 11 Jan 2023 12:15:36 GMT</pubDate></item><item><title><![CDATA[Reply to Gradient Mask Effect fails to transform on Wed, 11 Jan 2023 11:29:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> In Transparency panel menu: enable the Transform Mask Content, while the object is selected.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/17204</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/17204</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 11 Jan 2023 11:29:15 GMT</pubDate></item></channel></rss>
