<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Any way to move 2 selected anchor points in opposite direction?]]></title><description><![CDATA[<p dir="auto">Example:<br />
<img src="/forum/assets/uploads/files/1680901938977-10514c11-d68d-4f2e-8a7e-fe305662503b-image.png" alt="0_1680901938850_10514c11-d68d-4f2e-8a7e-fe305662503b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">In Inkscape I would just press Ctrl+&gt; or Ctrl+&lt; to walk the nodes towards or away from each other resulting in something like this<br />
<img src="/forum/assets/uploads/files/1680902158606-80e9d26a-7cde-403c-bf78-e71550c8ab4b-image.png" alt="0_1680902158152_80e9d26a-7cde-403c-bf78-e71550c8ab4b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any VS way of doing this?</p>
]]></description><link>https://www.vectorstyler.com/forum/topic/3017/any-way-to-move-2-selected-anchor-points-in-opposite-direction</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 13:05:06 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3017.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Apr 2023 21:16:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Sat, 08 Apr 2023 08:13:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a> said in <a href="/forum/post/18206">Any way to move 2 selected anchor points in opposite direction?</a>:</p>
<blockquote>
<p dir="auto">Step wise interactive change would have been nice</p>
</blockquote>
<p dir="auto">I added this to the feature request backlog.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18216</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18216</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 08 Apr 2023 08:13:22 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Sat, 08 Apr 2023 07:30:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a> said in <a href="/forum/post/18206">Any way to move 2 selected anchor points in opposite direction?</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Moving node/s a defined step is possible.</p>
<p dir="auto">You can change the value in the "... edit the movement by keyboard" field.<br />
When moving node/s with the arrow keys.</p>
<p dir="auto">Multiplier keys work also in the Transform panel.</p>
<p dir="auto">When I change a value with the mouse scroll wheel in the transform panel.<br />
Only with the mouse wheel the value changes by 1.<br />
Holding down the shift key changes the value by 10 units.<br />
If you use the Ctrl (win) key, the node will change in a fraction of 1.</p>
<p dir="auto">It is also possible to use the arrow keys in a value field<br />
"up" increases a value, "down" decreases it.</p>
<p dir="auto"><a href="https://recordit.co/9Mepxi4AmS" rel="nofollow ugc">Here a video</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18215</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18215</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Sat, 08 Apr 2023 07:30:34 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Fri, 07 Apr 2023 22:30:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> Thank you, this feels a bit counter intuitive, and I actually was wondering why the bounding box changed when switching between Node Tool and Select tool, but now I see that it changes context to selected nodes only. Very nifty!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18211</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18211</guid><dc:creator><![CDATA[syllie]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:30:08 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Fri, 07 Apr 2023 22:28:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a> said in <a href="/forum/post/18206">Any way to move 2 selected anchor points in opposite direction?</a>:</p>
<blockquote>
<p dir="auto">this opens the door for more tricks</p>
</blockquote>
<p dir="auto">your welcome</p>
<p dir="auto">because of Tricks <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=ec4d969cc53" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
<a href="https://recordit.co/6H3KPVaCHm" rel="nofollow ugc">here is another one</a></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18210</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18210</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Fri, 07 Apr 2023 22:26:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a><br />
• select the nodes;<br />
• switch to the Select/Transform tool (V) and…<br />
• Ctrl-drag to scale them by their bounding box.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18208</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18208</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:26:03 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Fri, 07 Apr 2023 22:20:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/subpath" aria-label="Profile: Subpath">@<bdi>Subpath</bdi></a> Thanks that is a nice way of solving it. Had not thought to use the transform panel for between-nodes operations (rather than on a full object) and this opens the door for more tricks. Step wise interactive change would have been nice but I can live with this!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18206</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18206</guid><dc:creator><![CDATA[syllie]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:20:23 GMT</pubDate></item><item><title><![CDATA[Reply to Any way to move 2 selected anchor points in opposite direction? on Fri, 07 Apr 2023 22:13:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/syllie" aria-label="Profile: syllie">@<bdi>syllie</bdi></a></p>
<p dir="auto">open the tranform panel<br />
Panels &gt; Transform</p>
<p dir="auto">select your (both) nodes<br />
and change the Value in the width<br />
or the scale field</p>
<p dir="auto"><a href="https://recordit.co/5kI3QRuv3I" rel="nofollow ugc">here a short video</a></p>
<p dir="auto"><img src="/forum/assets/uploads/files/1680905547593-nodes-width.png" alt="0_1680905481516_Nodes-width.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18205</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18205</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Fri, 07 Apr 2023 22:13:15 GMT</pubDate></item></channel></rss>
