<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.016 RC1]]></title><description><![CDATA[<h3>VectorStyler 1.0.016 RC1 release notes</h3>
<li>Improved: added preview button to <em>Create Adjustment Layer</em> view.</li>
<li>Fixed: image effect option edits were not registered when creating a new adjustment layer.</li>
<li>Fixed: some shape unions did not work with overlapping segments.</li>
<li>Fixed: shape editor modal view layout was broken when opening the first time.</li>
<li>Fixed: reset and show markers after screen change notification.</li>
<li>Fixed: snap to point and snap to shape to work better when both enabled.</li>
<li>Fixed: indicator for point snapping mode.</li>
<li>Fixed: scaling selected path nodes should not scale control points outside of selection.</li>
<li>Fixed: moving bend and other shape effect shape centers resulted in double distance move.</li>
<li>Fixed: crash in <em>Find Edge</em> image effect.</li>
<li>Fixed: opening popup menu from menu should not overlap.</li>
<li>Fixed: enabling <em>Blend Shapes</em> should keep shape effects.</li>
<li>Fixed: shapes to corners may result in zero length segments when converting to curves.</li>
<li>Fixed: confirming <em>Levels</em> field in <em>Posterize</em> effect did not work.</li>
<li>Fixed: enabling <em>Preserve Colors</em> in <em>Add Noise</em> effect discarded previous effects.</li>
<li>Fixed: some font names are not shown correctly in the font list.</li>
<li>Fixed: some numeric editors did not handle deletion and replacing.</li>
<li>Fixed: duplicating artboards with locked layers did not duplicate content correctly.</li>
<li>Fixed: rasterizing object may result in thin red contour.</li>
<li>Fixed: rasterizing multiple objects did not work.</li>
<li>Fixed: crash when editing the zoom blur effect options.</li>
<li>Fixed: <em>Flare</em> and <em>Lens Flare</em> effect options did not open.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/304/update-1-0-016-rc1</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:15 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/304.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Mar 2021 14:05:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.016 RC1 on Tue, 02 Mar 2021 21:14:40 GMT]]></title><description><![CDATA[<p dir="auto">@vectoradmin I know I said it before, but each version you release feels so much more smooth and efficient - less clunky. I was just playing around with this version you released today. Noticing a lot of small but important things you cleaned up and fixed. Great job!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/1208</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/1208</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 02 Mar 2021 21:14:40 GMT</pubDate></item></channel></rss>
