<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.082]]></title><description><![CDATA[<h3>VectorStyler 1.1.082 release notes</h3>
<li>Separate path when using the knife tool.</li>
<li>Fixed regression in eraser tool.</li>
<li>Cursor sensitivity when selecting text shapes.</li>
<li>Changed default shortcuts for node types in the node editor.</li>
<li>Added modifier (Control) for relative rotation snapping.</li>
<li>Fixed clipping blend objects into text shapes.</li>
<li>Fixed regression in offset path and stroke alignment.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3073/update-1-1-082</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:00:32 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3073.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 May 2023 13:04:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.082 on Sat, 13 May 2023 19:30:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/18687">update 1.1.082</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> Maybe the object is "rotated" inside the bounding box, which will make it look like rotating it with Ctrl-Shift doesn't work?</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1683887493286-slanted.png" alt="0_1683887489983_slanted.png" class=" img-fluid img-markdown" /></p>
</blockquote>
<p dir="auto">Ahhh, this might be the case, well done. I hadn't even considered that it was relative to the bounding box and NOT the actual vector itself - doh <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":-(" alt="😞" /><br />
My test was simply a bunch of lines <em>created</em> at odd angles - naturally, all those lines would have orthogonal bounding boxes <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">I had (stupidly ???) assumed that  VS would know if a vector was orthogonal or not and would rotate it accordingly.</p>
<p dir="auto">That's what I based my results on and obviously, that's not what the intended operation should be <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /><br />
Understandably, if one of my test lines were some complex object, then VS wouldn't know if it were orthogonal or not.</p>
<p dir="auto">In that case, you would have to do a collision detect of some part of the object to say an orthogonal guideline to ensure orthogonality, then you would be good to go.</p>
<p dir="auto">Thanks for that !</p>
<p dir="auto">Neil</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18698</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18698</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Sat, 13 May 2023 19:30:07 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Fri, 12 May 2023 10:33:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> Maybe the object is "rotated" inside the bounding box, which will make it look like rotating it with Ctrl-Shift doesn't work?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18687</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18687</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Fri, 12 May 2023 10:33:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Thu, 11 May 2023 14:57:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto"><img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18676</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18676</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Thu, 11 May 2023 14:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Wed, 10 May 2023 19:35:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> I will try to replicate this issue with the angle constrain</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18674</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18674</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 10 May 2023 19:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Wed, 10 May 2023 19:01:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a></p>
<p dir="auto">I have also just tried it on Windoze 10 on my Mac using Parallels - same results.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18673</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18673</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Wed, 10 May 2023 19:01:13 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Wed, 10 May 2023 18:33:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/18658">update 1.1.082</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a><br />
When 'Relative Angle Constrain' is enabled in Prefs &gt; Editing Options 1, only Shift is needed,<br />
and pressing Ctrl-Shift rotates in 45° increments ignoring the current rotation.</p>
<p dir="auto">When 'Relative Angle Constrain' is disabled, pressing Ctrl-Shift rotates in 45° increments + the<br />
current angle (say, 12°).</p>
</blockquote>
<p dir="auto">Nope, just tried it again, always the same whether relative angle constrain is checked or not <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f61e.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--disappointed" style="height:23px;width:auto;vertical-align:middle" title=":-(" alt="😞" /></p>
<p dir="auto">It <em>always</em> constrains relative to the current angle and <em>never</em> pulls the object back to 0 deg (or 45/90).</p>
<p dir="auto">I did check that I was on 082 just to make sure <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">Any thoughts, I'm guessing another pref conflict ?? (although I did do a reset ).</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18672</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18672</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Wed, 10 May 2023 18:33:18 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 20:20:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a><br />
]]></description><link>https://www.vectorstyler.com/forum/post/18658</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18658</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Tue, 09 May 2023 20:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 20:04:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/18654">update 1.1.082</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> The Control key thing works only when also holding the Shift key, and it should constrain the rotation relative to the current rotation of the object.</p>
</blockquote>
<p dir="auto">I tried a prefs reset with the same result. I don't need to use the control key, the shift key now rotates relative to the object's current angle, it doesn't force it to 0/90 as before. It seems that the relative rotate has been permanently installed ?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18657</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18657</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Tue, 09 May 2023 20:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 16:45:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> The Control key thing works only when also holding the Shift key, and it should constrain the rotation relative to the current rotation of the object.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18654</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18654</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 May 2023 16:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 15:05:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I reset both the settings and the workspace to defaults and using the control key is not constraining a shape's rotation in any way. Shift modifier is working.  Is there something more than needs to be turned on or off?</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18653</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18653</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 09 May 2023 15:05:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 13:40:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> I think only a Settings Reset might tell if the modifier keys were changed.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18652</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18652</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 May 2023 13:40:44 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 13:17:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I'm having the same situation as <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> but I'm not sure  I swapped around any modified keys in the past.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18651</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18651</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Tue, 09 May 2023 13:17:29 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 13:36:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/igull" aria-label="Profile: Igull">@<bdi>Igull</bdi></a> Did you have the modifier keys customized previously?<br />
That could mean that the new modifier keys are not used.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18650</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18650</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Tue, 09 May 2023 13:36:42 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Tue, 09 May 2023 12:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/b77" aria-label="Profile: b77">@<bdi>b77</bdi></a> said in <a href="/forum/post/18641">update 1.1.082</a>:</p>
<blockquote>
<blockquote>
</blockquote>
<p dir="auto">Nice. <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title="👍" alt="👍" /></p>
</blockquote>
<p dir="auto">Sorry, I'm not seeing this working ?</p>
<p dir="auto">Holding shift snaps the object by 45deg , holding ctrl simply switches off the rotation snapping. Holding shift + ctrl does the same as shift.<br />
I assume I'm missing something, I assumed one of them would force the object to 0 deg (say) then snap every 45 (or whatever your snap angles are set to) the other would simply snap relative to the object starting angle ?</p>
<p dir="auto">TIA</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18649</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18649</guid><dc:creator><![CDATA[Igull]]></dc:creator><pubDate>Tue, 09 May 2023 12:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Mon, 08 May 2023 23:32:36 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
]]></description><link>https://www.vectorstyler.com/forum/post/18641</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18641</guid><dc:creator><![CDATA[b77]]></dc:creator><pubDate>Mon, 08 May 2023 23:32:36 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.082 on Mon, 08 May 2023 14:37:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the updates - all are good improvements</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18620</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18620</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 08 May 2023 14:37:16 GMT</pubDate></item></channel></rss>
