<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.083]]></title><description><![CDATA[<h3>VectorStyler 1.1.083 release notes</h3>
<li>Fixed separate path regression when using the eraser tool.</li>
<li>Fixed the use of transparency content role and text inside transparency masks.</li>
<li>Allow cutting path at the selected node also in the scissor tool.</li>
<li>Fixed bug in the union operation on certain shapes.</li>
<li>Group opacity in CMYK mode to render correctly.</li>
<li>Allow selecting and changing same colors inside groups.</li>
<li>Clicking on an empty area with the magic wand tool should deselect.</li>
<li>Stroke width tool to allow insertion of new nodes near existing ones.</li>
<li>Union commands from context and path panels should use the same options.</li>
<li>Split text command on multiple selected text shapes to position text correctly.</li>
<li>Correct pivot point when rotating part of a path.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3095/update-1-1-083</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:00:18 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3095.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 May 2023 17:49:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.083 on Wed, 17 May 2023 17:14:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/boldline" aria-label="Profile: Boldline">@<bdi>Boldline</bdi></a> The context panel has the "deep select" mode for the transform tool. I tested with that.<br />
Also, the Magic Wand tool should "deep select" now.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18772</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18772</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Wed, 17 May 2023 17:14:18 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.083 on Wed, 17 May 2023 21:59:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/18717">update 1.1.083</a>:</p>
<blockquote>
<p dir="auto">Allow selecting and changing same colors inside groups.</p>
</blockquote>
<p dir="auto">Is there a setting in the "select' options that I need to click on to allow  for selecting and changing colors inside groups? Right now in build 84, I am selecting an object inside of a group with the node editing tool and I see the color show up in the color palette. I cannot change it by clicking on another color in the color palette or by using "select&gt;style" etc. Is there another setting I need to modify to get this to work?</p>
<p dir="auto">UPDATE: Seems like some things can be updated and some cannot within a group. I'll investigate further and report back.<br />
<img src="/forum/assets/uploads/files/1684343368306-aea3ba91-3ea6-4b7c-b9de-fc7963878669-bld-2023-05-17-at-13.07.52.png" alt="0_1684343367242_aea3ba91-3ea6-4b7c-b9de-fc7963878669-BLD 2023-05-17 at 13.07.52.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18771</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18771</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Wed, 17 May 2023 21:59:22 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.083 on Mon, 15 May 2023 17:57:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a></p>
<p dir="auto">just another one who is impressed <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">... Stroke width tool to allow insertion of new nodes near existing ones...</p>
<p dir="auto">works well now</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1684173454836-stroke-width.png" alt="0_1684173368221_Stroke width.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/18720</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18720</guid><dc:creator><![CDATA[Subpath]]></dc:creator><pubDate>Mon, 15 May 2023 17:57:49 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.083 on Mon, 15 May 2023 17:52:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Amazing how fast you can fix the bugs and issues! thank you</p>
]]></description><link>https://www.vectorstyler.com/forum/post/18719</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/18719</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Mon, 15 May 2023 17:52:14 GMT</pubDate></item></channel></rss>
