<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.0.017 RC1]]></title><description><![CDATA[<h3>VectorStyler 1.0.017 RC1 release notes</h3>
<li>Improved: better cursors to indicate rotation, resizing and skewing.</li>
<li>Improved: show object center while rotating or skewing.</li>
<li>Improved: transparency panel to adjust opacity and mask of the style selected in the appearance panel.</li>
<li>Improved: add opacity slider to the color panel.</li>
<li>Fixed: Wacom tablet input blocked with some tablet drivers.</li>
<li>Fixed: positioning of the document when printing with some printer drivers.</li>
<li>Fixed: adjustment filter by object did not use shape or content as a mask correctly.</li>
<li>Fixed: shape effect option button was missing in modal shape effect editor view.</li>
<li>Fixed: pixelate effect did not render correctly.</li>
<li>Fixed: resizing selected nodes only when first node is selected did not adjust control point correctly.</li>
<li>Fixed: editing width profile in offset path shape effect.</li>
<li>Fixed: when drawing new shapes, use all shape options set in the modal view.</li>
<li>Fixed: modifier for regular and normalize option of stars.</li>
<li>Fixed: also clear corners of shapes when reseting shape options.</li>
<li>Fixed: select all while in shape drawing mode should select all objects.</li>
<li>Fixed: deleting the first node in a closed shape did not create a correct approximation of the curve.</li>
<li>Fixed: changing a segment to line should set cusp nodes at both ends.</li>
<li>Fixed: adjust number of sides in super shape edits with arrow keys.</li>
<li>Fixed: pressing tab key in document view should not move focus away.</li>
<li>Fixed: show and use transformed shape effect indicators if object has been transformed after the shape effect.</li>
<li>Fixed: also move locked layers and objects when moving artboard from context panel.</li>
<li>Fixed: constrain point movement with Shift in 4 point distortion.</li>
<li>Fixed: copy and paste part of a path selected in the node editor.</li>
<li>Fixed: contour is too slow on complex shapes.</li>
<li>Fixed: large contour was broken on some shapes.</li>
<li>Fixed: crash in character tool.</li>
<li>Fixed: freeze in layers panel while working with symbols.</li>
<li>Fixed: color filters did not adjust parameters of stacked image effects.</li>
<li>Fixed: wrong limits for baseline offset and skew fields in the character panel.</li>
<li>Fixed: <em>Hidden</em> command from <em>Object</em> menu was not working.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/316/update-1-0-017-rc1</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 08:36:19 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/316.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Mar 2021 19:09:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.0.017 RC1 on Tue, 09 Mar 2021 11:03:00 GMT]]></title><description><![CDATA[<p dir="auto">I saw a huge improvement in the quality of the pointers on Win10 - that looks so much better now!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/1292</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/1292</guid><dc:creator><![CDATA[syllie]]></dc:creator><pubDate>Tue, 09 Mar 2021 11:03:00 GMT</pubDate></item></channel></rss>
