<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.1.091]]></title><description><![CDATA[<h3>VectorStyler 1.1.091 release notes</h3>
<li>Fixed regression when calculating shape effects inside symbol references.</li>
<li>Exporting (local) opacity masks to SVG.</li>
<li>Exporting symbol references from outside the artboard to SVG.</li>
<li>Expand stroke and convert to curve to keep opacity transformations.</li>
<li>Highlighting spot colors in pop-over palette panels.</li>
<li>Use copy and paste of objects while in the shape editor (no nodes are selected).</li>
<li>General stability improvements.</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/3243/update-1-1-091</link><generator>RSS for Node</generator><lastBuildDate>Sun, 22 Nov 2026 07:50:20 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/3243.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Jun 2023 06:12:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.1.091 on Sat, 08 Jul 2023 08:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I get the issue just by changing the colour of one stroke or the size etc.<br />
but Ctlr+R just solves the "issue" every time (well, not a real issue):</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1688803809754-bug.jpg" alt="0_1688803809914_bug.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">After Ctrl+R:</p>
<p dir="auto"><img src="/forum/assets/uploads/files/1688803831679-cr.jpg" alt="0_1688803832327_CR.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19701</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19701</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Sat, 08 Jul 2023 08:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Sat, 08 Jul 2023 07:46:29 GMT]]></title><description><![CDATA[<p dir="auto">@Pat I tried moving / changing objects on artboard 2, and in all cases the blend is updating for me.<br />
Maybe a short recording might help.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19700</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19700</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Sat, 08 Jul 2023 07:46:29 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Fri, 07 Jul 2023 14:15:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> file sent (with 5 artboards so far) <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19697</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19697</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 07 Jul 2023 14:15:06 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Fri, 07 Jul 2023 14:04:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> I can send you the file I'm working on right now (see <a href="https://www.vectorstyler.com/forum/topic/3259/posters-using-vs-from-blend-image-effect-to-pattern-etc/8">here</a>). The issue occurred when I was dealing with Artboard 2.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19696</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19696</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Fri, 07 Jul 2023 14:04:40 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Fri, 07 Jul 2023 13:40:28 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/19666">update 1.1.091</a>:</p>
<blockquote>
<p dir="auto">when I'm dealing with blended shapes, I have to refresh (Ctrl+R) after each change (whatever it is) because some shapes disappear</p>
</blockquote>
<p dir="auto">I cannot replicate this issue. Can you send me an example? Thanks!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19695</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19695</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 07 Jul 2023 13:40:28 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Thu, 06 Jul 2023 07:31:43 GMT]]></title><description><![CDATA[<p dir="auto">@Pat said in <a href="/forum/post/19666">update 1.1.091</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">I will try to replicate and fix this ASAP.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/19667</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19667</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Thu, 06 Jul 2023 07:31:43 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Thu, 06 Jul 2023 07:21:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> v1.091: when I'm dealing with blended shapes, I have to refresh (Ctrl+R) after each change (whatever it is) because some shapes disappear, are displaced, etc . Can this be improved ? Thanks <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19666</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19666</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Thu, 06 Jul 2023 07:21:19 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Mon, 26 Jun 2023 07:01:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/19560">update 1.1.091</a>:</p>
<blockquote>
</blockquote>
<blockquote>
<li>Use copy and paste of objects while in the shape editor (no nodes are selected)</li>
</blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Works great, thanks <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/263a.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--relaxed" style="height:23px;width:auto;vertical-align:middle" title=":relaxed:" alt="☺" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19562</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19562</guid><dc:creator><![CDATA[B-Vs-V]]></dc:creator><pubDate>Mon, 26 Jun 2023 07:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.1.091 on Mon, 26 Jun 2023 06:58:00 GMT]]></title><description><![CDATA[<p dir="auto">Great release <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/19561</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/19561</guid><dc:creator><![CDATA[gotanidea]]></dc:creator><pubDate>Mon, 26 Jun 2023 06:58:00 GMT</pubDate></item></channel></rss>
